weird house wiring problem
/ weird house wiring problem #1
Mosey
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I’m no expert at house wiring, but I thought I understood the basics. I’m replacing a bathroom light with a light that has an exhaust fan. There’s only one switch there now, so I needed to add a second switch to have one control the light and one control the fan. So, I started by adding another wire (I got lucky here and didn’t have too much trouble running a new wire down from the attic to the box).
Before I even hooked up the new wire or installed the new light, I removed the existing switch and replaced it with a new switch that has 2 single pole switches that I found at Lowes. It fits in a single wide switch box and the switches flip sideways instead of up and down. So, I connected the wires that went to the old switch to one of the switches on the new switch. I connected the black (hot) wire to the hot side of the switch and the white wire (which will become a hot wire when the switch is turned on) to one of the switch terminals on the other side. I didn’t connect the ground wire to anything yet. Simple right? When I turned the breaker back on, the light came on even though the switch was turned off! Flipping the switch back and forth made no difference. The light just stayed on all the time. I tried the other switch and the same thing. So, I took it off and put the old switch back on and it worked like it should.
So, I took the old switch back off and turned the breaker on. I used a volt meter to measure from the black wire to the box (metal) and it read 125V, like it should. I measured from the white wire to the box and it measured 0V, like it should. I put the new switch back in and the light stayed on all the time again. I called Lowes and they said they’ve never had anyone return a switch because it was bad and asked me to double check my wiring, so I did. But, I got the same results. I tried switching the wires so the white wire went to the hot side of the switch and that made no difference, so I switched it back and did some more measuring. From the ground on the switch to the box, it read 125V! That did not seem right to me. So, I took the switch off and did some measuring with and ohm-meter. I connected one lead of the ohm-meter to the hot side of the switch and the other to one of the switch terminals on the other side. When I turn the switch on, it goes to 0 ohms, like it should. When I turn the switch off, it goes to infinity, but not right away, it gradually goes up and takes 12 seconds to get to infinity. Also, there are no shorts between the ground and any of the terminals.
At this point, I determined that the new switch as acting strange and must be defective, so I put the old switch back in and forgot about it for a while and went and worked in the garage. But, it kept bugging me, so I took my garage light switch out and put the new switch in place of it. It worked perfectly!
I have a BSEE, but my expertise is with digital electronics, not house wiring and I’m stumped on this one!
/ weird house wiring problem #2
Danny,
I've got 26 years in the electrical field and it has me stumped too. Do you have a way to snap a pic of your switch after you connect it? I'll look at it and see if something looks goofy.
/ weird house wiring problem #3
All of the white wires should be tied together, as they are the neutral side of the circuit. You should also run ground to the switch box (if metal) and to the fan/vent enclosure. The black side is your hot side. You should only have black wires to your switches (or red if you are using a 3 conductor cable - didn't sound like you were though). The "input" side of your switches should be the black feed wire from your breaker box and should be common to both switches. The output of one switch should be the black wire to your light. The output of the second switch should be the output to your fan. NEVER switch the neutral (white) side - only the hot (black) side.
You may also want to confirm that your ground is good back at the breaker box. The ground is a safety measure to prevent things like switch boxes riding up to 120 VAC if the neutral opens up. You will note that ground wires are usually smaller - they are for protection - not for load carrying. The only place you want ground and neutral tied together is at the breaker box. One last thing - this being a bathroom, you should be running off of a ground fault protected circuit (GFCI). You either should have an outlet "upstream" of your switch that is a GFCI type or a GFCI breaker (much more expensive then the outlet).
Sake Mense?
/ weird house wiring problem #4
Andy,
All of that made sense to me, but you can also "back-feed" a switch. In that case there would be a white wire on the switch. Sounded to me like he had a switch loop with a white and a black wire on the old switch.
Jerry, I don’t have a digital camera or a scanner. So, I’ll try to describe it better. I took the existing black wire and connected it to the side of the switch where there is a breakout tab (which I did not break). It’s labeled “+ LINE +” and the screw has a black coating on it. I connected the existing white wire to the other side of the switch on the bottom screw. It has no label and it’s a bright brass colored screw. I did not connect anything to the other bright brass colored screw on the top of the same side or to the green colored screw in the middle of that side (which is connected to the metal part of the switch that attaches the switch to the box). I also tried connecting the white wire to the top screw on that side when it didn’t work, but it made no difference.
Andy, I am breaking the hot side of the circuit. The “wire” has 3 individual wires, 1 black, 1 white, and 1 bare, with another layer of black insulation going around all 3. The black one is hot all the time, so I’m assuming it goes back to the breaker box via a junction box. I’m also assuming the white one goes to the hot side of the light via the junction box. So, it’s actually a hot wire, but it’s white. The way I understand it, it’s supposed to have been painted black on the ends but whoever wired the house didn’t do that. The bare wire is connected to the metal switch box. The house was built in 1978, so all the boxes are metal. I’m also assuming the other side of the light has a white wire going back to the breaker box via the junction box. There is a ground fault protected outlet plug in this bathroom, but it’s on a separate circuit. The light switch was just a normal switch. Maybe the new switch I have is only supposed to be used in a ground fault protected circuit? Although, if that’s the case, it shouldn’t have worked in the garage.
I went to Lowes today and bought another new switch just like this one, plus 2 others that are slightly different (they fit into a different type of switch plate and have rocker type switches). So, when I get home tonight I’ll see how these act.
/ weird house wiring problem #6
Yup - if the previous run had power to the appliance and a "switch run" out to the switch you would have exactly that - good catch.
/ weird house wiring problem #7
Danny,
Sounds as if you hooked it up properly. The only thing I would caution is, usually it is the black wire (in this type of situation) that is the return to the light, but they did some screwy things back in the 70's also.
/ weird house wiring problem #8
Get someone to help you that knows wiring. From what you describe, you are hooking it up wrong, and it is not a bad switch. Also, you are getting confused with the other responses, as they either don't understand your situation, or are talking about possible situations that you do not have.
For your safety, get some help.
The three wires you describe - black, white, and bare copper - are hot, neutral, and ground in a 2 wire w/ground cable. The black should feed one side of the double switch connected by a strap. The other side of the switch should have two separate terminals - one for each switch. From each of those terminals should be a black wire running to the fan, and another black (or red) wire running to the light. These are hot when the switch makes them hot. The white wire feeding into the box should be connected to the one white wire going to the fan/light (if you have three wire w/ground cable. If you have 2 wire w/ground cable, then both of the white wires should be connected to the white feed wire. The bare copper ground wires should be connected in the box and be connected to the box, switch, and the fan chassis. At the fan/light end, there should be one or two white wires that should be connected to the white wires comming from the switch.
Be safe, and know what you are doing, and do not guess. You may accidentally have the chassis of the fan/light wired to 110 and just make the connection between it and ground. Curtains!!!
"usually it is the black wire (in this type of situation) that is the return to the light"
Jerry, I've been wondering which way it was supposed to be. It appears that it was done backwards in this case, since the black wire is hot all the time. I guess I'd better dig around some more in the blown in insulation and find that junction box and take a look inside!
/ weird house wiring problem #10
Did you wire it like either of these circuits?
I left the ground off on purpose.
/ weird house wiring problem #11
beenthere,
Maybe I have misunderstood, but I think he has only one cable coming into the switch box. The "back-feeding" of the switch is being done in a junction box or the light box itself.
Beenthere,
“For your safety, get some help.”
I am asking everyone I know and posting here!
“The three wires you describe - black, white, and bare copper - are hot, neutral, and ground in a 2 wire w/ground cable.”
Yes, that is exactly what I have.
“The black should feed one side of the double switch connected by a strap.”
Again, that’s exactly what I have.
“The other side of the switch should have two separate terminals - one for each switch. From each of those terminals should be a black wire running to the fan, and another black (or red) wire running to the light. These are hot when the switch makes them hot.”
I have not yet installed the new fan/light, the original light is still in place. I also have not connected anything to the new cable I pulled through. All I’m doing right now is trying to make one of the switches in my new double switch work in place of the original single switch using the original wires. I don’t understand what you mean when you say to run a black wire to the light (or fan), because I’ve already used the black wire that’s in the cable to connect to the “feed”/“line” (hot) side of the switch so all I have left is the white wire.
“Be safe, and know what you are doing, and do not guess.”
I appreciate your concern. Believe me, I am being careful. I’m just getting ideas from people and hoping someone will say something that will make me say to myself “oh, that’s it!”. When I get this all done I plan to use my volt meter to check for voltage between the metal casing of the light and ground.
MossRoad,
However, I am planning to do it like the diagram on the bottom if I ever get this figured out.
/ weird house wiring problem #15
My apologies for getting a little too excited. I have re-read your original posts after getting your responses to me, as well as the others, and now agree that something seems to be wrong with the switch. Can you get a continuity check using the ohmeter across the new switch?
I now understand what the Inspector was saying to you, and MossRoad's diagram should be the correct way to go, as you intend.
As far as digging for the junction box, even in '76 the wiring code (if followed) would suggest the connections should be in the light, and not in a hidden junction box.
I will bow out, as it looks like you are in better hands with the help from the others. Hard to do this by long distance, but you will prevail.
Good luck.
/ weird house wiring problem #16
Exactly how many of each color wire do you have in your switch box. In a normal single pole light switch box there will be two 14-2 wires coming into the box. Each will have one black, one white and one copper. You would then hook up your hot black to the side of the switch with the strap and then there should be a black wire that continues on to the light. That black wire would be connected to one of the two screws on the dual output side of the switch. Both white wires are then connected with a wire nut and the copper bare wires are connected and pig tailed to the metal box. If you don't have two black wires in the box I a little confused on how it was originally wired.
Jeff
/ weird house wiring problem #17
Sounds like you've got a good handle on the way it is supposed to work. I eagerly await your findings with the different switches. Good luck and let us know what you find out.
/ weird house wiring problem #18
Danny,
There is a good possibility that the "junction box' is the light box. Hopefully they did not send the black down as hot and the white back as the return. But they may have. I bought a house built in '64 and the idiot that wired it switched the neutral at all the lights. Thats begging someone to get hurt. I have switched everything around to the proper way ( I think). Feel free to call me if you want to. I will send the phone number in a message to you if you want it.
/ weird house wiring problem #19
If he has only one piece of Romex in the box than Jerry (inspector507) is correct and it has been backfed. If this is indeed the case, the switch box has no Neutral in it, it is up in the light, the hot leg is coming down from the light on either the black or the white and than traveling through the switch and back to the light on the opposite conducter.
Depending on how the electrition was tought back when it was originally wired, he could have either made the black or the white his hot leg. If I remember right, Danny said it was the black that was hot in this case. My father who was a Master electrition for 30 yrs. tought me in this case to take the white wire, which would now become hot when you flip the switch and identify it as such with tape.
Before I installed the new switch again, I would take an ohmmeter and identify which screws work with which switch.
The hot screws will be easy to identify for they are connected with the breakaway tab.
Hopefully there’s an attachment with this post. It shows the way other lights in my house are connected. Is this what you are calling a “back-feed” or “switch loop”? But, these lights are in a room addition, and not part of the original house. This bathroom light is in the original part of the house, so it was probably done by a different person and it might be wired different. I need to get my volt meter and do some more checking to see if the bathroom light is wired backwards.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
New Holland 5030 Tractor (A61166)
New Holland 5030...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
Year: 2003 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 139746 miles Plate: Body (A61568)
Year: 2003 Make...
378897 (A61166)
378897 (A61166)
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
