Weird GST shift action - issue or no biggie?
/ Weird GST shift action - issue or no biggie? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I had a weird delayed shift with my L4200GST - it only happened once, and I don't think it's a big deal, but with the 2700 hours on the tractor, you never know. I was pulling a gauge-wheeled landscape rake on my driveway - I was admittedly getting antsy and pushing too fast, cruising along in 5th on a flat, but pulling a decent pile of stuff on the rake so the tractor was under a load. I did a no-clutch bump into 6th (first road gear) and nothing happened - no shift. There was a good 5 second delay or better, than **FOOM** the shift happened. It startled me and I dropped it right back down into 5th, which shifted immediately, and nothing bad happened after, but it still made me nervous. I figured that the tranny was under load, which bound the old gear until there was a slight break in the load, allowing the shift to happen. I don't know what is in a GST transmission or how one works, but it seems plausible. Sound OK?
/ Weird GST shift action - issue or no biggie? #2
Sounds Normal... an up shift with a load while the trans is changing ranges, will involve a delay while the pressures in the GST adjust to operate the hydraulic clutch And then the gear changes...
/ Weird GST shift action - issue or no biggie? #3
Sounds normal to me also, it's when it doesn't shift at all, you start to wonder...
Jay, I've been looking at one of your old thread's,,
http://www.tractorbynet.com/forums/...egarding-use-backhoe-hyd.html?highlight=L4200
I will be 'resurrecting it, if you don't mind, I'm installing a hoe on my machine and
will need some advice on where to hook up the lines for it.;)
I see you have the same set-up, so your input will be appreciated.
'K - thanks. It was the length of the delay that had me concerned - like 5+ seconds or so. I was beating on it. Also, performed sacrilege and got a BX today. It's just SO bitty...
My original setup was just loader and 'hoe. There was a quick connect at the loader that either ported the power beyond output either to the 3pt hitch or to the 'hoe. The backhoe is plumbed 2-line only - pressure in and return to sump. The 3pt is disabled while the hoe is connected. Hope this helps.
2012 Ford F-350 Service Truck (A61568)
2012 Ford F-350...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A61568)
2002 Freightliner...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
2017 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2017 Ram 1500 4x4...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
