Weird GST shift action - issue or no biggie?
/ Weird GST shift action - issue or no biggie? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I had a weird delayed shift with my L4200GST - it only happened once, and I don't think it's a big deal, but with the 2700 hours on the tractor, you never know. I was pulling a gauge-wheeled landscape rake on my driveway - I was admittedly getting antsy and pushing too fast, cruising along in 5th on a flat, but pulling a decent pile of stuff on the rake so the tractor was under a load. I did a no-clutch bump into 6th (first road gear) and nothing happened - no shift. There was a good 5 second delay or better, than **FOOM** the shift happened. It startled me and I dropped it right back down into 5th, which shifted immediately, and nothing bad happened after, but it still made me nervous. I figured that the tranny was under load, which bound the old gear until there was a slight break in the load, allowing the shift to happen. I don't know what is in a GST transmission or how one works, but it seems plausible. Sound OK?
/ Weird GST shift action - issue or no biggie? #2
Sounds Normal... an up shift with a load while the trans is changing ranges, will involve a delay while the pressures in the GST adjust to operate the hydraulic clutch And then the gear changes...
/ Weird GST shift action - issue or no biggie? #3
Sounds normal to me also, it's when it doesn't shift at all, you start to wonder...
Jay, I've been looking at one of your old thread's,,
http://www.tractorbynet.com/forums/...egarding-use-backhoe-hyd.html?highlight=L4200
I will be 'resurrecting it, if you don't mind, I'm installing a hoe on my machine and
will need some advice on where to hook up the lines for it.;)
I see you have the same set-up, so your input will be appreciated.
'K - thanks. It was the length of the delay that had me concerned - like 5+ seconds or so. I was beating on it. Also, performed sacrilege and got a BX today. It's just SO bitty...
My original setup was just loader and 'hoe. There was a quick connect at the loader that either ported the power beyond output either to the 3pt hitch or to the 'hoe. The backhoe is plumbed 2-line only - pressure in and return to sump. The 3pt is disabled while the hoe is connected. Hope this helps.
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
POLY TANK ON SADDLE MOUNT (A62131)
POLY TANK ON...
Harlo HP6500 (A60462)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2019 F-550 Bucket Truck (A63118)
2019 F-550 Bucket...
New Holland Workmaster 25S Tractor/Mower (A61166)
New Holland...
