Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
The existing alt is dirty, and as excess heat, often from dust/dirt stuck to fan blades etc. can cause electronics to run erratically, and or fail due to lack of cooling needed to dissipate excess heat from the voltage regulator, diodes and the like.
The voltage regulator is at the top of the alt, with the 2 torx screws holding it's rectangular shape in place. If it were my machine I'd thoroughly blow out all evidence of dust and dirt from the existing alt, and fan blades, including using contact cleaner or small doses of Brakleen on the various terminals and connections going to/from the alt.
This might not solve your problem, but it might show visible signs of burnt sections of the alternator that another pic after cleaning could help us verify what may be happening.
Or you could just bolt up the new one and be done with it at this point, hoping that the alt is the culprit.
Do they core charge on those puppies? If not, I'd keep the old alt for possible use by someone else who might be able to get yours rebuilt for a fraction of the cost of a new one; or for you as a rebuildable spare, just in case.
And whatever you do, try like h^5l to keep the new one clean by periodic compressed air use.
