weight question
/ weight question #1
firefighter jim
In general, which is heavier, the front half of a tractor or the rear half? Thanks in advance. (Just the tractor with no attachments)
/ weight question #2
I am guessing the rear is heavier since it seems to sink in the mud first. With the way some of the tractors have the front axle set back they may be close to 50/50.
Bill
/ weight question #4
The definitive answer is "it depends".
If the rear tires are unloaded, no wheel weights, no front weights, no Front end loader, then the front is heavier. If you add fluid to the tires, then the rear is heavier. If you have a front end loader, then the front is often heavier. If you have a front weight box or a rear weights that changes it too.
An empty tractor is designed to be nose heavy so pulling won't flip the front up.
jb
3ft Metal Rooster (A65583)
3ft Metal Rooster...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
6' 3-Pt Bush Hog Mower (A66408)
6' 3-Pt Bush Hog...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
ELECTRIC MOTORS WITH PUMP (A65643)
ELECTRIC MOTORS...
