Weight of filled tires
   / Weight of filled tires #1
BXman98
St. Albans VT
Kubota BX2370
If you fill the rear tires of a kubota BX2370 with R4's, how much will the tires both weigh after filled with ballast?
   / Weight of filled tires #2
I think about 10 gallons per tire. So it depends on what you fill it with. WW fluid is ~8# per gallon, so that would add 80#. Rimguard or calcium is ~11# per gallon, so would add 110# to the empty tire weight. Which I would guess to be maybe 40#
   / Weight of filled tires #3
RimGuard has a table that lists by tire size weight and gallons.
   / Weight of filled tires #4
R4 tire size for kubota BX straight from the kubota specs list 26x12-12.
   / Weight of filled tires #6
A 26x12-12 holds 10 gal.
Should I use WW fluid or Calcium or rim guard for being uphere in northern Vermont?
   / Weight of filled tires #8
In the Pacific NW we have a company called Tire Distribution Systems. TDS quote estimate was $77 front, $112 rear, each, Turnaround in 2-4 days.
TDS said the estimation table suggested 44 lbs each for front, 114lbs each for rear. But they billed for 51 lbs in the fronts and 133 lbs each rear. I did not weigh the wheels before or after,,,,, wish i had.
BX24 Front Tire Size 18X8.5-10
BX24 Rear Tire Size 26X12-12
I don't have the BX24 anymore (sold it).
holy crap that's way to expensive, i think that me and my father will just go to a family friends garage and have them fill it.
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
