Weight of filled tires
   / Weight of filled tires #1
BXman98
St. Albans VT
Kubota BX2370
If you fill the rear tires of a kubota BX2370 with R4's, how much will the tires both weigh after filled with ballast?
   / Weight of filled tires #2
I think about 10 gallons per tire. So it depends on what you fill it with. WW fluid is ~8# per gallon, so that would add 80#. Rimguard or calcium is ~11# per gallon, so would add 110# to the empty tire weight. Which I would guess to be maybe 40#
   / Weight of filled tires #3
RimGuard has a table that lists by tire size weight and gallons.
   / Weight of filled tires #4
R4 tire size for kubota BX straight from the kubota specs list 26x12-12.
   / Weight of filled tires #6
A 26x12-12 holds 10 gal.
Should I use WW fluid or Calcium or rim guard for being uphere in northern Vermont?
   / Weight of filled tires #8
In the Pacific NW we have a company called Tire Distribution Systems. TDS quote estimate was $77 front, $112 rear, each, Turnaround in 2-4 days.
TDS said the estimation table suggested 44 lbs each for front, 114lbs each for rear. But they billed for 51 lbs in the fronts and 133 lbs each rear. I did not weigh the wheels before or after,,,,, wish i had.
BX24 Front Tire Size 18X8.5-10
BX24 Rear Tire Size 26X12-12
I don't have the BX24 anymore (sold it).
holy crap that's way to expensive, i think that me and my father will just go to a family friends garage and have them fill it.
CAT Skid Steer (A50322)
CAT Skid Steer...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
