Weight of concrete
   / Weight of concrete #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Does anybody know the weight of a cubic foot of concrete? I starting to build a ballast for the 3PH. I just don't want to over do it/w3tcompact/icons/laugh.gif.
Derek
   / Weight of concrete #2
My engineering ref book has a range of light wt of 68 lbs to hvy weight 0f 200 lbs. Concrete with gravel as the aggregate has a avg. weight of 150 lbs per cubic foot
   / Weight of concrete #3
Concrete Heavy
W/baryte aggregate 200 lbs/cu-ft
Concrete Lightweight
W/expanded clay aggregate 68 lbs/cu-ft
Concrete Limestone aggregate
w/portland cement 148 lbs/cu-ft
Concrete
W/ gravel 150lbs/cu-ft
From "Thomas J. Grover" handy dandy little pocket reference/w3tcompact/icons/smile.gif
About 150 lbs/cu-ft
   / Weight of concrete #4
Derek -
A "normal" mix, fully cured weighs about 150 pounds per cubic foot.
Can't remember where I got the info, but I looked it up when I was thinking about making my own concrete beams and wanted to be sure I could move them with my tractor.
Concrete beams?
Don't ask. /w3tcompact/icons/crazy.gif
   / Weight of concrete #6
Jeff,
You are quick. You beat me by a full 4 minutes, I think we agree on concrete. What a nice board, ask and you shall receive./w3tcompact/icons/smile.gif
   / Weight of concrete #7
Concrete beams, OK I won't ask.
I once was looking really hard @ a concrete boat/w3tcompact/icons/smile.gif
Again don't ask.
   / Weight of concrete #8
Yeah, I saw a concrete boat once, and I've also seen that floating concrete bridge across Lake Washington at Seattle. I still think that must be a figment of someone's imagination./w3tcompact/icons/wink.gif
Bird
   / Weight of concrete #9
Bird,
Which bridge did you see. About 10 years ago the first floating bridge didn't/w3tcompact/icons/frown.gif It sank in a storm when someone forgot that hatches should be closed. We have a new one now. Two floating bridges in Washington have gone to the bottom. The other was the Hood Canal bridge.
I wished I could have seen "Galloping Gurdy" when it went down.
   / Weight of concrete #10
I remember hearing about that bridge I saw in '72 sinking, but truth is, I'd forgotten about it. It was already gone when I passed through there in '91, I believe. I guess it's an artificial reef now? They didn't try to remove it, did they?
Bird
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53473)
Kuhns AE10 Small...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
Mini Excavator (A52377)
Mini Excavator...
2024 Deere 317G (A50123)
2024 Deere 317G...
