Weight of concrete
   / Weight of concrete #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Does anybody know the weight of a cubic foot of concrete? I starting to build a ballast for the 3PH. I just don't want to over do it/w3tcompact/icons/laugh.gif.
Derek
   / Weight of concrete #2
My engineering ref book has a range of light wt of 68 lbs to hvy weight 0f 200 lbs. Concrete with gravel as the aggregate has a avg. weight of 150 lbs per cubic foot
   / Weight of concrete #3
Concrete Heavy
W/baryte aggregate 200 lbs/cu-ft
Concrete Lightweight
W/expanded clay aggregate 68 lbs/cu-ft
Concrete Limestone aggregate
w/portland cement 148 lbs/cu-ft
Concrete
W/ gravel 150lbs/cu-ft
From "Thomas J. Grover" handy dandy little pocket reference/w3tcompact/icons/smile.gif
About 150 lbs/cu-ft
   / Weight of concrete #4
Derek -
A "normal" mix, fully cured weighs about 150 pounds per cubic foot.
Can't remember where I got the info, but I looked it up when I was thinking about making my own concrete beams and wanted to be sure I could move them with my tractor.
Concrete beams?
Don't ask. /w3tcompact/icons/crazy.gif
   / Weight of concrete #6
Jeff,
You are quick. You beat me by a full 4 minutes, I think we agree on concrete. What a nice board, ask and you shall receive./w3tcompact/icons/smile.gif
   / Weight of concrete #7
Concrete beams, OK I won't ask.
I once was looking really hard @ a concrete boat/w3tcompact/icons/smile.gif
Again don't ask.
   / Weight of concrete #8
Yeah, I saw a concrete boat once, and I've also seen that floating concrete bridge across Lake Washington at Seattle. I still think that must be a figment of someone's imagination./w3tcompact/icons/wink.gif
Bird
   / Weight of concrete #9
Bird,
Which bridge did you see. About 10 years ago the first floating bridge didn't/w3tcompact/icons/frown.gif It sank in a storm when someone forgot that hatches should be closed. We have a new one now. Two floating bridges in Washington have gone to the bottom. The other was the Hood Canal bridge.
I wished I could have seen "Galloping Gurdy" when it went down.
   / Weight of concrete #10
I remember hearing about that bridge I saw in '72 sinking, but truth is, I'd forgotten about it. It was already gone when I passed through there in '91, I believe. I guess it's an artificial reef now? They didn't try to remove it, did they?
Bird
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
Frontier GM1084 (A50123)
Frontier GM1084...
2005 Ford E350 XLT SD Passenger Van (A53117)
2005 Ford E350 XLT...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
Hose Reel (A53424)
Hose Reel (A53424)
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
