Weight Distribution Hitch
   / Weight Distribution Hitch #11
Make sure you get a ball (or balls) rated for what you are going to pull. And carry an assortment of balls. When I went to rent a U haul tow dolly it required a 2" ball and U haul was out, so I had to drive a half hour to get a ball.
Also make sure you can hook up the chains. Most of the WDH's I looked at wouldn't fit my Hudson due to where the battery box is welded on.
The ball I get will be rated for the load. I have an assortment of ball mounts and balls. I have a 2'' ball that is rated for 7500. I had a 7k car trailer that took a 2'' ball.
Do you have a picture of your trailer and how the WDH is on it? I think I may have the same problem with a dump trailer.
   / Weight Distribution Hitch #13
Here's a pic of the problem
Specs for the hitch were
Sway-control bracket positioning: 27" - 32" back from center of coupler
.Equal-i-zer Weight Distribution w/ 4-Point Sway Control - No Shank - 14,000 lbs GTW, 1,400 lbs TW Equal-i-zer Weight Distribution EQ90-00-1401
Most other hitches were similar and when I talked with E-qualizer and other WD mfg tech reps they strongly advised against moving the hanging bracket in as far as I would need to in order to miss the battery box (about the 22" point). And none of them went out farther.
At the time I didn't weld so I didn't want the extra cost of moving the box. And I didn't want to bolt a bracket into the frame. I'm picky at times.
I ended up moving the bar under the tongue box further back. The bracket fits under the cord just beyond the box. All is well. It's made 3 or 4 loaded trips down to Mississippi.
Specs for the hitch were .Equal-i-zer Weight Distribution w/ 4-Point Sway Control - No Shank - 14,000 lbs GTW, 1,400 lbs TW Equal-i-zer Weight Distribution EQ90-00-1401
Thanks, I see, the equalizer is adjustable. I have seen some hitches that have short or long bars.
   / Weight Distribution Hitch #15
If I remember correctly the more weight you have the longer the bar you want. I've put about 9K on my Hudson and it's always towed like a dream w/ my 2002 7.3 dually at HIGHway speeds. Tows better if kept under 75 when passing big trucks or being passed by big tucks.
   / Weight Distribution Hitch #16
I don't have a "name brand" WD, it was supplied by the dealer when I bought by TT..Different in that the bars insert through the bottom and not mounted to the top as was my last one..It does a great job with the anti-sway and all of the fire-power built into my truck. The physics of this stuff is very impressive.
   / Weight Distribution Hitch #17
I've got 3 different WD systems with 5 different hitch heads. One is an old Reese 7k system. Works great up to its weight limit. Then I have a 10k (maybe 12 can't remember) Reese system that I bought when I bought the new camper. It works great once I got it adjusted correctly when the dealership didn't have it quite right and I broke the hitch head, but Reese stood behind it anyway and sent me a new hitch head, after I had already bought one, so now I have a spare. Then I needed a WD system for my utility trailer. I ended up ordering a Curt from Amazon. I didn't need much "bar" on the trailer, so I always kept the hitch head up straight. I then ordered another hitch head w/ a longer drop to use with the Suburban. Never had any issues with it until this past summer when Mom bought another camper that was just a bit too heavy for my old 7k system. But since it was closer to the same hitch height as my utility trailer I used the Curt, but now I needed more bar. I adjusted the head back to get it, but unlike the Reese, it is a smooth connection. The Reese has ridges to keep it from moving. I can feel the hitch head sliding back and forth on the shank. It has a short "block" (for lack of a better term) to supposedly stop this, but it isn't long enough for where I want the hitch head set. So if you would have asked me prior this summer, I would have given 2 thumbs up on the Curt, now, not so much.
BTW, it is the same hitch that is pictured in the link.
Thanks for the reply. I looked at the Reese WDH's and saw that the washers have ridges on them. I will definitely take this into consideration before I buy one.
2016 Ram 1500 Pickup Truck, VIN # 1C6RR7XTXGS346729 (A44391)
2016 Ram 1500...
2011 Ford F-550 Service Truck (A42742)
2011 Ford F-550...
2015 Indian River Water Sprayer Trailer (A42742)
2015 Indian River...
1987 Miller 40' Citrus Trailer (A44500)
1987 Miller 40'...
2006 Takeuchi TL130 Compact Track Loader Skid Steer (A42742)
2006 Takeuchi...
NEW 25 GAL DEWALT AIR COMPRESSOR NEW SUPPORT EQUIPMENT (A40023)
NEW 25 GAL DEWALT...
