Weight & Dimensions for Gravel
   / Weight & Dimensions for Gravel #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Can someone lead me to a good website that will give me weight specs for gravel/rock/sand as well as dimensions for as an example a yard of material. Also I'm looking for calculations for area, an example would be that if I want to fill an area of a particular size, how do I calculate how much material I need. Is my request, clear as mud ??
Please Advise
Thanks
Eric
Thanks Brian, you da man !!!
Did you get my pm ??
Thanks
Eric
   / Weight & Dimensions for Gravel #6
Hey.....just do not do what I did. Needed some crushed limestone so I headed to the local dirt pit place and the guy that loaded me got a bit carried away. Managed to get 6000LBS in the 3/4 ton ford. No power....no steering....and stopping was a bit hard. The guy that loaded me offered to take some out but I thought I would make her home. 12 miles @ 20mph got me home safely!!!
   / Weight & Dimensions for Gravel #7
Were those springs on the rubber bumpers /forums/images/graemlins/shocked.gif
Usually 1.5 yards is plenty of rock, not only for weight but especially to unload from a non-dump bed on a 4x4. That typically will have the springs within a few inches of the rubber bumpers. On a 3/4 ton, that is.
A 4x4 usually lowers the GVWR of a pickup too.
   / Weight & Dimensions for Gravel #8
Dimensions: to answer in visual terms -
A linear yard is 3 feet, and a cubic yard is 3 feet per side. (27 cubic feet). To illustrate this cube, imagine the shipping carton for a television.
If your driveway is 9 ft wide and a foot thick, then a cubic yard of material will extend the driveway three more feet. (linear dimensions of 3 yards x 1/3 yard x 1 yard = 1 cubic yard).
More realistically, build it a half foot thick and that cubic yard of material will make 6 more linear feet of driveway. Or make it 1/3 of a foot thick - yup, that cubic yard of material will extend the driveway 9 ft.
This should get you started!
   / Weight & Dimensions for Gravel #9
When figuring concrete for an estimate I use eighty square feet per yard when planning on four inch thickness. But when figuring gravel or sand I use fifty square feet.
So a ten yard dump will give you a ten by fifty area four to six inches cover like in a driveway.
Sand, rock, limestone, etc I figure at twenty five hundred pounds per yard. They vary depending upon aggregate but the twenty five hundred pounds is a good guesstimator.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2001 Ford F150 (A50121)
2001 Ford F150...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
