Weight & Dimensions for Gravel
   / Weight & Dimensions for Gravel #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Can someone lead me to a good website that will give me weight specs for gravel/rock/sand as well as dimensions for as an example a yard of material. Also I'm looking for calculations for area, an example would be that if I want to fill an area of a particular size, how do I calculate how much material I need. Is my request, clear as mud ??
Please Advise
Thanks
Eric
Thanks Brian, you da man !!!
Did you get my pm ??
Thanks
Eric
   / Weight & Dimensions for Gravel #6
Hey.....just do not do what I did. Needed some crushed limestone so I headed to the local dirt pit place and the guy that loaded me got a bit carried away. Managed to get 6000LBS in the 3/4 ton ford. No power....no steering....and stopping was a bit hard. The guy that loaded me offered to take some out but I thought I would make her home. 12 miles @ 20mph got me home safely!!!
   / Weight & Dimensions for Gravel #7
Were those springs on the rubber bumpers /forums/images/graemlins/shocked.gif
Usually 1.5 yards is plenty of rock, not only for weight but especially to unload from a non-dump bed on a 4x4. That typically will have the springs within a few inches of the rubber bumpers. On a 3/4 ton, that is.
A 4x4 usually lowers the GVWR of a pickup too.
   / Weight & Dimensions for Gravel #8
Dimensions: to answer in visual terms -
A linear yard is 3 feet, and a cubic yard is 3 feet per side. (27 cubic feet). To illustrate this cube, imagine the shipping carton for a television.
If your driveway is 9 ft wide and a foot thick, then a cubic yard of material will extend the driveway three more feet. (linear dimensions of 3 yards x 1/3 yard x 1 yard = 1 cubic yard).
More realistically, build it a half foot thick and that cubic yard of material will make 6 more linear feet of driveway. Or make it 1/3 of a foot thick - yup, that cubic yard of material will extend the driveway 9 ft.
This should get you started!
   / Weight & Dimensions for Gravel #9
When figuring concrete for an estimate I use eighty square feet per yard when planning on four inch thickness. But when figuring gravel or sand I use fifty square feet.
So a ten yard dump will give you a ten by fifty area four to six inches cover like in a driveway.
Sand, rock, limestone, etc I figure at twenty five hundred pounds per yard. They vary depending upon aggregate but the twenty five hundred pounds is a good guesstimator.
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
We do NOT accept credit cards as payment. (A50123)
We do NOT accept...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
