Weight Box / Tool Box. Thanks Paul
   / Weight Box / Tool Box. Thanks Paul #1
Bigtyme
Stewartstown. Pa
Mahindra max 28
Well, Ive been working on my welding skills and I wanted to build my own box rather then buy one. The idea is the bottom half will be fill with concrete, about 800lbs . The top will house a couple chain saws, ax, hammer , oil and fuel. It turned out pretty good just not sure if I should add anything else before I sand and paint. The inside will have a wood floor and will be sprayed with bed line to protect the blades on my saw's. I'm hoping to paint it red if I can find the perfect match for Mahindra. Special Thanks to Paul Short for the inspiration, I really enjoyed challenging myself.
   / Weight Box / Tool Box. Thanks Paul #2
I can't believe there's no comments on this yet. My God man I have to tell you that you did an outstanding job on that. To say I'm impressed would be the biggest understatement of 2017 so far. I like to think out the details weather they are big or small on my projects and you never missed one on this job. It's easy to see you put a lot of time into this before you even picked up the tools to stat it. Your welds are great, the fit and finish is perfect and top points for the design. Take it for what it's worth but I have to grade it at a "A+"
Hands down one of the best I've seen in a ballast box build. Not saying this because you gave me a little credit which I do appreciate. It don't happen often but it truly is an outstanding job.
Tip my lid to you. Thanks for posting.
   / Weight Box / Tool Box. Thanks Paul #3
Great looking box. Should work well for years. But what I really like is the shop. Clean, organized. And using the lift as a welding table is a great idea. Now I have to go clean out enough space in my shop to replace a car radiator, but even clean up, won't look like that.
   / Weight Box / Tool Box. Thanks Paul #4
Great looking box and concept. Nicest one I've ever seen. Wish someone out there would make one like this for folks like me with no welding skills. I bet they could sell quite a few.
   / Weight Box / Tool Box. Thanks Paul #5
My comment is :cool2:
My suggestion is since you are using a quick hitch, remove that neat top link pin and replace it with a 7/8 bolt through the bushing.
   / Weight Box / Tool Box. Thanks Paul #6
Great looking box. Nicest one I've ever seen. Wish I had one.
   / Weight Box / Tool Box. Thanks Paul #7
That is awesome! Great collection of ideas all put together! Thanks for posting pictures! Only other thing I can think of adding would be a set of heavy duty casters underneath so that when you drop it off you could roll it out of the way ! Nice shop!
   / Weight Box / Tool Box. Thanks Paul #8
Very nice fab job. Alot of really good ideas and a great design. That looks like that should work very well. It will really look good when you get it painted up to match your tractor. I would think Mahindra would make a quart of paint to match it up. That is what I do for my Kubota orange when I get something that size to paint. Nicely done!!! And as others have said, great looking shop.
Funny you should say that. I was planning on it but wasn't sure if I should use a bolt or just weld in a piece of round stock
Thanks Paul ,I'm hoping to paint primer this weekend or maybe add a few more things to it. Keep the videos coming and go check out a mahindra so I can get some ideas. Glad you made it through the storm. I'll get up there one day
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2003 Big Tex 10PI...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2019 Chevrolet Tahoe (A56859)
2019 Chevrolet...
