Weighing tongue weight at home.
   / Weighing tongue weight at home. #11
   / Weighing tongue weight at home. #12
Something else that might work is to use your rear bumper height as scale.
Say you want a 600# tongue weight. Measure your unhitched bumper height with three 200# people standing on the bumper. Then lean a yardstick against the bumper, hitch up, and drive your tractor on until the bumper sags to that 600# height.
I wouldn't extrapolate the 600# height to a much heavier tongue weight, in case your rear spring rate is non-linear. And next time, your bed should have the same loading as when you took the 600# measurement, if your accomplices aren't handy.
   / Weighing tongue weight at home. #13
My scale is so old, it only goes to 250 pounds!
A 250 pound scale will work fine.
Just need to pick a lever arm length/ratio that will work for you.
I can measure my desired 1,400 lb tongue load with my 250 lb. scale.
I then screw a wheel chock to the trailer deck, for next time loading.
   / Weighing tongue weight at home. #15
Or for a few bucks you can build your own tongue (or other item) scale. Buy the cheapest 2 ton jack you can find. Drill a hole at the base of the cylinder. Most have a flat spot that is perfect. Thread it and install a pressure gauge. On mine I measured the ram size and calculated that I needed to multiply the gauge reading by .7 to get the actual weight.
   / Weighing tongue weight at home. #16
orezok, good idea but what if that ram has a larger piston inside?
   / Weighing tongue weight at home. #17
All you would have to do is put a known weight on it to get the correction factor.
Bruce
   / Weighing tongue weight at home. #19
That must have been a BIG freaking bird house! What's he trying to attract, Pterosaurs? :D
Reminds me of my Dad.
He went to the hardware store to get 100' of 12/3 wire for his birdhouse. They thought he was crazy,
His bird house was about 24'x8' and housed pigeons, ducks, a few chickens. and peacocks.
Never could tell what "two eggs" for breakfast meant - could be from two pigeon eggs to 2 peacock eggs.
I may have done a $100 worth of work getting there...
Yeah I fiddled around with 2x4's and bathroom scales till I finally bought a Sherline Trailer Tongue Weight Scale.
Propride link has them on sale for $130.
   / Weighing tongue weight at home. #20
You measure the size of the ram bore and calculate the square inches. Dia. x Dia. x.7854 gives you area. In my case that was .7 in so I multiply the gauge pressure by .7 to get actual load. PSI x area
2010 Ford F-150 Pickup Truck (A55973)
2010 Ford F-150...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
METAL STORAGE RACK (A52708)
METAL STORAGE RACK...
1998 PETERBILT 379 (A58214)
1998 PETERBILT 379...
2016 Snorkel S4732 Scissor Lift (A57453)
2016 Snorkel S4732...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
