Weighing tongue weight at home.
   / Weighing tongue weight at home. #11
   / Weighing tongue weight at home. #12
Something else that might work is to use your rear bumper height as scale.
Say you want a 600# tongue weight. Measure your unhitched bumper height with three 200# people standing on the bumper. Then lean a yardstick against the bumper, hitch up, and drive your tractor on until the bumper sags to that 600# height.
I wouldn't extrapolate the 600# height to a much heavier tongue weight, in case your rear spring rate is non-linear. And next time, your bed should have the same loading as when you took the 600# measurement, if your accomplices aren't handy.
   / Weighing tongue weight at home. #13
My scale is so old, it only goes to 250 pounds!
A 250 pound scale will work fine.
Just need to pick a lever arm length/ratio that will work for you.
I can measure my desired 1,400 lb tongue load with my 250 lb. scale.
I then screw a wheel chock to the trailer deck, for next time loading.
   / Weighing tongue weight at home. #15
Or for a few bucks you can build your own tongue (or other item) scale. Buy the cheapest 2 ton jack you can find. Drill a hole at the base of the cylinder. Most have a flat spot that is perfect. Thread it and install a pressure gauge. On mine I measured the ram size and calculated that I needed to multiply the gauge reading by .7 to get the actual weight.
   / Weighing tongue weight at home. #16
orezok, good idea but what if that ram has a larger piston inside?
   / Weighing tongue weight at home. #17
All you would have to do is put a known weight on it to get the correction factor.
Bruce
   / Weighing tongue weight at home. #19
That must have been a BIG freaking bird house! What's he trying to attract, Pterosaurs? :D
Reminds me of my Dad.
He went to the hardware store to get 100' of 12/3 wire for his birdhouse. They thought he was crazy,
His bird house was about 24'x8' and housed pigeons, ducks, a few chickens. and peacocks.
Never could tell what "two eggs" for breakfast meant - could be from two pigeon eggs to 2 peacock eggs.
I may have done a $100 worth of work getting there...
Yeah I fiddled around with 2x4's and bathroom scales till I finally bought a Sherline Trailer Tongue Weight Scale.
Propride link has them on sale for $130.
   / Weighing tongue weight at home. #20
You measure the size of the ram bore and calculate the square inches. Dia. x Dia. x.7854 gives you area. In my case that was .7 in so I multiply the gauge pressure by .7 to get actual load. PSI x area
LONG 2460 TRACTOR (A58374)
LONG 2460 TRACTOR...
2015 Chevrolet 2500 Silverado 4X4 Crew Cab Pickup Truck (A55973)
2015 Chevrolet...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
Toro Workman HD Utility Cart (A56857)
Toro Workman HD...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
