Weeds
/ Weeds #1
Walkin Horse
Platinum Member
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
What is this weed
Sent from my iPhone using TractorByNet
/ Weeds
Thanks. Roundup will kill it but I have to stay on top of it. I guess those little burrs bust open and it spreads then another dose of round up.
/ Weeds #5
I knew a old Mexican man in Arivaca AZ
He told me it was good for asthma he called it Toloache.
I thought he was just a ignorant old fool
But then I did a search just now and found this.
Medicinal Plants of the SW: Datura stramonium
I guess I am the ignorant one
------J
/ Weeds #6
Also known as Thornapple or Moonflower. I have 3 of them in my yard; they produce some pretty blooms early in the morning. The seeds are toxic, and as I recall, the leaves and stems may be also. They come back every year; I just cut them down in the fall. We consider them to be an interesting ornamental.
/ Weeds #8
And locoweed for hallucinogenic properties (Datura stramonium - Wikipedia, the free encyclopedia)
Steve
From the article:
"There is a high risk of fatal overdose amongst uninformed users, and many hospitalizations occur amongst recreational users who ingest the plant for its psychoactive effects."
It was on the news here a couple of years ago; some kid swallowed a bunch of seeds and ended up in the emergency room.
/ Weeds #9
Yes, as a past EMT, we hauled a few of them to the ER.
/ Weeds
I just read the article. Apparently it will cure colds moles and sore a holes. When I saw the name loco weed I had to laugh. Most of the weed is growing in a horse paddock. I remember seeing a movie one time where Burt Lancasters horse ate some and he had to ride it out.
So is the best treatment round up or dig and remove. I thought about burning them but I that might make the seed spread. After they have been sprayed the bigger ones linger for awhile. This stuff was probably brought in to my place in a load of hay. It has been spreading for 2 or 3 years.
/ Weeds #11
Try a 2, 4-D or dicamba. As roundup can struggle with small seeded broadleafs.
/ Weeds
I have some Gordon's Trimec 2-4-d. I have always used roundup because it's safe to use around the horses. I not sure that 2-4-d is something I can spray in the paddocks without taking the horses out for a awhile.
/ Weeds #13
The Gordon's you mention only has a lawn label. But after checking other products with Ag labels there is no mention of a grazing restriction. Only a haying restriction of 7 days. We spray with cattle in the feild all the time with no problems.
/ Weeds #14
I find glyphosate (Roundup etc) kills it very easily. I still get the odd seed germinating, but very few, and had quite a lot when we moved here in 2003. When I was in NSW, Australia in the 1980s my neighbours called it Castor Oil Plant. It is not of course, but they gave it the same name.
/ Weeds #15
In areas, that I have weeds, and black berrys, I mix both glyposate and 2-4-d in the sprayer, and every thing is dead along the path of the spray. Real quick.
/ Weeds #16
Toxic is the best medicine... it kills what it treats :doctor:
/ Weeds
I'm going to try the roundup and 24d mix today. I will let you know how it works for me.
/ Weeds
I wonder if I smoked it if would help my hemroids. So far not knowing what it was I guess I have been lucky that the horse haven't tried it.
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
PENDING SELLER CONFIRMATIONS (A59909)
PENDING SELLER...
John Deere 2555 Tractor with Loader (A61166)
John Deere 2555...
Utility Cart (A59231)
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
