Weeds
/ Weeds #1
Walkin Horse
Platinum Member
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
What is this weed
Sent from my iPhone using TractorByNet
/ Weeds
Thanks. Roundup will kill it but I have to stay on top of it. I guess those little burrs bust open and it spreads then another dose of round up.
/ Weeds #5
I knew a old Mexican man in Arivaca AZ
He told me it was good for asthma he called it Toloache.
I thought he was just a ignorant old fool
But then I did a search just now and found this.
Medicinal Plants of the SW: Datura stramonium
I guess I am the ignorant one
------J
/ Weeds #6
Also known as Thornapple or Moonflower. I have 3 of them in my yard; they produce some pretty blooms early in the morning. The seeds are toxic, and as I recall, the leaves and stems may be also. They come back every year; I just cut them down in the fall. We consider them to be an interesting ornamental.
/ Weeds #8
And locoweed for hallucinogenic properties (Datura stramonium - Wikipedia, the free encyclopedia)
Steve
From the article:
"There is a high risk of fatal overdose amongst uninformed users, and many hospitalizations occur amongst recreational users who ingest the plant for its psychoactive effects."
It was on the news here a couple of years ago; some kid swallowed a bunch of seeds and ended up in the emergency room.
/ Weeds #9
Yes, as a past EMT, we hauled a few of them to the ER.
/ Weeds
I just read the article. Apparently it will cure colds moles and sore a holes. When I saw the name loco weed I had to laugh. Most of the weed is growing in a horse paddock. I remember seeing a movie one time where Burt Lancasters horse ate some and he had to ride it out.
So is the best treatment round up or dig and remove. I thought about burning them but I that might make the seed spread. After they have been sprayed the bigger ones linger for awhile. This stuff was probably brought in to my place in a load of hay. It has been spreading for 2 or 3 years.
/ Weeds #11
Try a 2, 4-D or dicamba. As roundup can struggle with small seeded broadleafs.
/ Weeds
I have some Gordon's Trimec 2-4-d. I have always used roundup because it's safe to use around the horses. I not sure that 2-4-d is something I can spray in the paddocks without taking the horses out for a awhile.
/ Weeds #13
The Gordon's you mention only has a lawn label. But after checking other products with Ag labels there is no mention of a grazing restriction. Only a haying restriction of 7 days. We spray with cattle in the feild all the time with no problems.
/ Weeds #14
I find glyphosate (Roundup etc) kills it very easily. I still get the odd seed germinating, but very few, and had quite a lot when we moved here in 2003. When I was in NSW, Australia in the 1980s my neighbours called it Castor Oil Plant. It is not of course, but they gave it the same name.
/ Weeds #15
In areas, that I have weeds, and black berrys, I mix both glyposate and 2-4-d in the sprayer, and every thing is dead along the path of the spray. Real quick.
/ Weeds #16
Toxic is the best medicine... it kills what it treats :doctor:
/ Weeds
I'm going to try the roundup and 24d mix today. I will let you know how it works for me.
/ Weeds
I wonder if I smoked it if would help my hemroids. So far not knowing what it was I guess I have been lucky that the horse haven't tried it.
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2023 TAKEUCHI TL8R2 SKID STEER (A62129)
2023 TAKEUCHI...
TEST YOUR BID BUTTON! (A62131)
TEST YOUR BID...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
429872 (A61166)
429872 (A61166)
Cat CB24B (A60462)
Cat CB24B (A60462)
