Weed Control Questions
/ Weed Control Questions #1
beersngars
Ohio
Kubota L3400HSD
Not sure if this is the right place but here goes. What will kill ALL weeds and briars for a long period of time? I would like to do all my trails (in woods) and driveway. Tried Round-Up, deisel, gas, ect with little success. Thinking of tring some brine water. Any thoughts?
/ Weed Control Questions #3
Round-up should work for a while. Did you spray enough and was it prepared with really clean water?
Your comments about trying diesel and gas are scary to me, seeing as how I like to drink my groundwater.
The Round-Up didn't touch the briars so I tried spraying them with deisel and gas to kill it then hoped the Round-Up would keep it dead. That program didn't produce great results. My brother in-law is in the oil patch biz and he says brine will do the trick but may kill trees if too much is used. That scares me.
/ Weed Control Questions #5
There was a post similar to this a couple of weeks ago. The original poster was asking how to control weeds on his gravel and whether there were any home made remedies.
I decided I would do a little experimentation on whether any of the home remedies work.
Salt Water
This is supposed to kill plants. I took a big bag of dishwasher salt and put a lot of it in a 5 gallon bucket. Then in a watering can and watered all the weeds that grow along the edge of our drive.
1 Week later they are still there but seem off colour. They might die or they might recover. Dunno yet but it is not quick.
Piles of Salt
I tried putting small handfulls of the same salt as above sprinkled over individual weeds. This did work well and they have died off. :) But it took a lot of salt and took a while to put the salt on the weeds.
Bleach
This kills plants of instantly. I did a very small area and they shrivelled up quickly. It might work well with salt water as well.
Vinegar
This does nothing. Even pure vinegar on a weed will not get rid of it. It just gets ill for a while and recovers. Useless
Hot Water
This didn't really work either. Nothing happened apart from the weed shrivelling up a bit and it was unconvenient to do.
Alcohol
This works well :D I used some cleaning thing based on methanol and the weeds shrivelled right up.
Diesel
This works as well as alcaohol. Oil does the same. Gas didn't work so well, I think it evaporated.
You could try some bleach on your briars and they should go away :D
(But I didn't tell you to do that :))
/ Weed Control Questions #6
There are sprays that will kill weeds and brush for awhile but they usually come back in time. There are generic forms of RoundUp that work well but the best I've found for multiflura rose and poison ivy is RoundUp Brush and Weed Killer. I used atrazine and gromaxine (a burndown spray combo for no-till) for poison ivy this spring and was sure I had killed it and now it looks as green and healthy as can be.
I have heard local farmers talk about Spike. I'll look into it. The Round-Up I used came from Lowes. It was mixed a little strong, but got expensive and lacked results.
Grrrr, the gas and deisel methods were best when mixed. Same results as you on evaporation. A 50/50 mix worked best. Be sure not to fire up a smoke in the area for a while.:p :p
/ Weed Control Questions #8
Round-UP is a non-selective enzyme inhibitor herbicide. Basically, it kills everything is comes in contact with.
A few things to keep in mind. DO NOT mix it "strong" It will end up burning the foliage and not killing the plant. Only irritating the plant and making it grow back stronger.
At the time of application, you will need a warm day and a time of the year when the plant is actively growing. If the plant is not taking in nutrients, it will not take in the RU.
If you are still unsure, a call to your local cooperative extension office will point you in the right direction.
/ Weed Control Questions #9
Roundup also just works when taken in by foliage it does nothing to the seeds in the ground that have not germinated yet thus the apparent regrowth.
Spike and others of the like actually work through ground sterilization of a type which means nothing will grow on the soil for some time after application.
I would also recommend you contacting you local county extension service if you have one they are a wealth of very valuable local information.
/ Weed Control Questions #10
Roundup only kills actively growing green foliage. Doesn't work well in a drought or on brush with chlorophyll in the stem, such as greenbrier. Spike is able to leach into soil, if it rains hard, can wash into unintended areas, and kill desirable trees or shrubs. I would suggest that you look up Sahara herbicide from Dow. With all herbicides, FOLLOW LABEL INSTRUCTIONS- a little more may do more harm than you think, both to the environment and you.:cool: :cool:
/ Weed Control Questions #11
This may have been posted already.
But... Be VERY careful w/ the Spike. If you get it inside the drip ring of a tree you want to keep, it probably won't live. Spike will not kill persimmon, by the way.
I have some Princep that I use around old equipment, structures and other stuff that doesn't move. At a high enough rate it is a soil sterilizer. Once again, don't get it near anything you want to keep.
/ Weed Control Questions #12
Get some of this: index
Understand though, that you'll probably have to retreat every year because seeds will be in the ground and blow in. Old used motor oil works too...
/ Weed Control Questions #13
Garlon 4 works well on briars here in south Georgia.
/ Weed Control Questions #14
I use Pramitol 25E. It is a bare ground herbicide. Nothing will grow for at least a year if you follow the directions on the label and you don't have to have a license to buy it. Here is a site where you can look at it. I buy it at Tractor Supply and also at my local farm & home store. This is by far the best bare ground product that I have ever used.
index
/ Weed Control Questions #15
Grrrr said:
Bleach
Alcohol
Diesel
Any thoughts on what these substances might/will do sprayer components? I seem to recall that methanol (wood alky) never caught on for vehicle fuel as it had a habit of corroding/disintegrating fuel system components.
I'd like to find something to take care of our tumbleweeds. I like the idea of contacting the county extension office for advice.
/ Weed Control Questions #16
another vote for pramitol. just be careful as it will also kill desirables. maybe look at roundup and surflan and a 24d. I remember as a kid crankin the ice cream maker, when done dad would take the salt brine and pore it on the cracks of the sidewalks, worked good until it rained, then would spread into the yard further and further with each rain. didn't bother him as much as grass in the sidewalk i guess as we did it every year.
an off topic question, well not really, but in the midwest and east as much salt as is used on the roads, how can their be anything growing in the borrow pits? and doesn't that work as baitin deer to the edge of the road? Ron
/ Weed Control Questions #17
Instead of Roundup I buy Pronto from TSC at less than half the price. I use it with near 100% sucess on poison ivy, briars, brush, grass, or weeds. As others have said, mix using the suggested rates. If it's been dry, wait for a good soaking rain and then spray after a week when things begin to grow. some things will slowy die after weeks, but they do die and won't regrow except from seeds. Roundup does work slightly better, especially if it rains within hours after application.
/ Weed Control Questions #18
In out area utility companies have transformer stations that have gravel areas fenced off and they keep them clear of any vegitation with a product called Sahara.
/ Weed Control Questions #19
Look for a generic round-up (something with glyphosate in it) and mix it with some surfactant (spreader-90 is what we use at work). and just for kicks and giggles throw some of a product called SelectMax in the mix. this is the mixture we spray on Round-up Ready Soybeans. the SelectMax is a grass killer that works on plants that are glyphosate resistant. thats the mix we use at work.
another product to use would be gramoxone. but i'm fairly certain that you need a license to buy it.
2018 FREIGHTLINER CASCADIA 125 T-A SLEEPER TRACTOR' (A67147)
2018 FREIGHTLINER...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2019 Mercedes Sprinter 2500 Cargo Van (A64556)
2019 Mercedes...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
