Wearplate for FEL
   / Wearplate for FEL #1
Anonymous Poster
Epic Contributor
Is anyone familiar with a hard plastic/rubber edge that mounts to the edge of a FEL to prevent damaging concrete while plowing snow? I have a BX 22 and someone told me about this but I can't find such a thing
   / Wearplate for FEL #2
I've seen them for large loaders but not for compacts. They make them out of polyethylene. It would be easy to make if you had a bolt on cutting edge cause you could remove the metal edge and replace it with the poly for the winter. If you have a welded edge it's more problematic.
   / Wearplate for FEL #3
<A target="_blank" HREF=http://www.google.com/search?hl=en&ie=ISO-8859-1&q=snowplow+edges&btnG=Google+Search>http://www.google.com/search?hl=en&ie=ISO-8859-1&q=snowplow+edges&btnG=Google+Search</A>
polyurethane, no ethylene. Check out this search - there were a bunch of manufacturers
   / Wearplate for FEL #5
HDPE: High Density Polyethylene
   / Wearplate for FEL #7
let us know if u run across such a thing, have never heard of it. i usulally just curl the bucket up a bit and go slow till i get most of the snow off, then when i can see, i do some fine scraping,
   / Wearplate for FEL #8
If you do a search for snowplow blades or cutting edges, several companies will come up. I'll look at the office to find some I've bookmarked Monday, but that's how I found them.
   / Wearplate for FEL #9
I plow snow commercially in Michigan. I have been approached by companies in Vermont and the northeast to buy this. Supposedly they use it on highway-bound snow plows. In some cases it replaces the cutting edge, in others it has a backer plate. In either case it is made of cast urethane but looks like is came from a sheet or plate. It's about 1-1/2" thick and costs about $40 per INCH! Keep in mind that in this application the cutting edge is at about a 30-degree attack angle. In your application it will be less than a few degrees if not zero to the ground.
It is entirely feasible to find an engineered, off-the-shelf plastic that has excellent wear and temperature properties. Call your local plastics supplier--probably won't cost more than $75. I would make it the same size and shape as your existing (removable??) cutting edge. I wouldn't chamfer the front edge as that could cause it to "chunk" or "chip" upon impact.
   / Wearplate for FEL #10
What I did was to bolt a 2 x 4 on either side of the bucket, 1 ½" width side down, about ½" below the front blade. Now it slides along the 1 ½" wide piece of wood and does not scratch the driveway. Worked great when picking up mulch dumped in the driveway this summer. I think it will do just a well with the snow and a lot $$ then $40 an inch. Two 18" 2 x 4, 4 -2 ½ by 5/16 bolts a few washers and nuts and about 30 minutes is all it takes.
Tom
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A51692)
2023 Fat Truck...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
Sweeper (A51691)
Sweeper (A51691)
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
