Wearing rings
/ Wearing rings #41
I wear my ring all the time and a watch a lot of the time. I did have a spark plug wire arc into my ring once. I've been jolted by spark plug wires more than once, but only the one time on my ring. It just left a slight gouge in the ring, lots of volts but not many amps.
The only close call I've had was from a wasp sting on my ring finger. I don't really react to bee stings, but wasp stings are pretty bad for me. I didn't think much of it at the time, but my daughter said something a few minutes later about taking my ring off. Lucky she did because after a few more minutes, it wouldn't have come off.
/ Wearing rings #42
Tool&Die Maker for 45 years. Wearing rings was frowned upon. I wore them anyway, and still have all my fingers. I saw alot... A guy, and a few women get their hair caught in the spindle of a drill press, but not even OSHA in all their "wisdom" demanded shaved heads. I got more injuries because of government mandated stupidity..
Worked with a guy that had a huge scar the length of his face. Had a large die ring chucked in a lathe. Apparently the chuck loosened overnight... Next morning, hit the lever... Wham-O... Sometimes accidents are not accidents, and this guy had it comin'... It's a different world in machine shops today since the computer "geeks" took over, buuuttttt...
Experience trumps safety devices, and the pencil pushers that mandate them, every time!
/ Wearing rings #43
I rarely wear my ring while working as well, just not comfortable. My wife will sometimes point it out...I should direct her to this thread. All fingers thus far still attached.
/ Wearing rings #44
oh.. it'd come off.. but either by a ring cutter at the er or via the paramedic. or via a pair of wire cutters. BTDT on the last one.. had to ring-ectomy my self one time when i smashed a finger and had no hopes of getting the ring off.. swelling set in within seconds.. i was still seeing starts when it swelled up :)
/ Wearing rings #45
I've seen a close call a few times and just had one myself a couple of weeks ago. We had a guy get his hand smashed and had to take his ring off with wire cutters while on the way to the hospital, think he might have lose the finger if we didn't. I had to go to the ER and hospital for a week due to an illness and the ring was the last thing on my mind. The ER folks messed up the IV and pumped fluid into my hand, which looked like a Michelin man glove! Luckily someone noticed my ring and got it off before the point of no return.
/ Wearing rings #46
yikes!
/ Wearing rings #47
A digit or extremity can go for at least 6hours with little to no blood...
Have seen a patient with a severed arm at the shoulder (when we left hospital about 3 hrs after it was severed he was on his way to a Trauma center and the arm was white)
Learned later that it was successfully reattached.
Although it is important to get the ring off to avoid complications it often can be removed much later with positive results.
Just my personal experience. Not telling anyone to wear or not wear rings.
Best practice is still to remove the ring ASAP
/ Wearing rings #48
it hurt too much to leave it on.. ;)
/ Wearing rings #49
I learned the hard way.
I was going down the ladder from a P3 military aircraft, and my ring caught on some bolt threads that were exposed, and ripped/skinned my finger from the base to the knuckle. The blood helped slide the ring off when I got to the bottom of the ladder. I threw the strip of meat/skin away.
No more rings after that, and no watches. I am not a time watcher. Besides, every cell phone has a clock on it.
/ Wearing rings #50
My wife fell and broke her wrist a couple of years ago. Her ring was already tight, and the swelling prevented us from removing it.
The doctor wanted to wait a few days before he casted the break to allow for the swelling. He said the ring must come off before he put on the cast, either he could do it or we could have a jeweler remove. He suggested a jeweler because his method was crude and the ring would most likely be destroyed.
The jeweler had this nifty cutter that ground a thin kerf through the band.
After her wrist healed, she took the ring back to the jeweler, had it resized and repaired. Good as new.
/ Wearing rings #51
i think my buddy a emt has a neat lil cutter in his kit that cuts rings.. makes a thin cut as well.. lil diamond blade.. etc..
/ Wearing rings #52
luckily i'm one of those time aware kind of people.. I can get within minutes per day of estimating the time... and as you point out.. phones have clocks. i havn't worn a watch in 10ys at least... besides.. when i did wear them.. they got stuck to speaker magnets.. or got caked in grease.. or the band caught and wripped on a bolt.. or lense cracked on tractor sheet metal.. gouged.. etc..
/ Wearing rings #54
rd_macgregor said:
Although we used dimestore rings when we got married (and presumably still have them somewhere), neither my wife nor I wear a wedding band.
Now, if you REALLY wanted to show confidence in your marriage, you could get a tatooed ring...
BOB
O you mean like mine? You can see on the bottom where it wore off except for one little dot
/ Wearing rings #55
As an office worker, I always have my ring on. The only time I take it off is for softball games and such. Mine is tungsten and black ceramic... it can't be cut off. My wife and I are both keenly aware if anything ever happens that the rings have to come off immediately so that the finger can stay..
/ Wearing rings #56
As much as I don't care for tat's, I think that is a better idea than wearing a ring. Especially in your profession. I have always worked around too many dangerous things through the years. Even though now I work in an office.. I just wont wear one.
/ Wearing rings #57
/ Wearing rings #58
When I married, my wife understood perfectly why I couldn't wear a ring on the job or working around home......she bought me a fancy new belt buckle and said "it doesn't come off unless I'm in the room - got it?" ...yes ma-am.
/ Wearing rings #59
I wonder if it would protect from minor crushing because of the strength of the tungsten
/ Wearing rings #60
probably.. but when it did crush.. I'd be real worried. my gold one deformed under a rush and I couldn't get it off fast enough..:) and it was easy to cut off with a pair of wire cutters!
