wearing gloves
/ wearing gloves #61
All this talk about being naked without your gloves reminded me of something I came across a while back
/ wearing gloves #62
There was a time, way back in the dark ages, when I wore both a class ring and a wedding band. But on December 29, 1965, I was the passenger in a police sedan when we hit a tree head on hard enough that the impact broke my seat belt so I still stuck my head into the windshield (thank goodness that uniform cap saved my face and eyes), my feet were jammed into the floor hard enough that both feet were black and blue even on the tops of my feet, I had a broad nearly black strip across my lower abdomen where the belt had been, and both hands hit the dash. Someone at the hospital took my rings off (for which I'm grateful). It was over a month before the swelling went down in my hands and fingers enough that I could get those rings back on, but I haven't worn them since, and have no intention of ever wearing a ring again.
/ wearing gloves #63
With gloves, clothes, etc getting pulled into a chainsaw sounds like the safest way is to play lumberjack in the nude!! OK maybe some briefs to tie up loose ends... :D
As for me?
Cutting with a saw I do not wear gloves.
moving wood I do, ever grab a spider or scorpion?
Metal work I wear gloves - I'll still grab a hot piece of steel bare handed from time to time.
Mechanic work, use to never wear a glove, these days I have several of the pair Soundguy mentioned and use them in really greasy jobs. most of the time I do not. As a mechanic I never liked the finger-tip-less gloves either. To add these days I'll put on a long sleeve t-shirt when working on things. It helps to keep the dirt/grease off the arms making it easier to clean up later.
Working/riding the tractor, no gloves.
Hunting, bow, gun, wear gloves. 90% of the time the wool GI leather glove liners($5 at the Army surplus) are warm enough down here. During the bow season I may switch to cotton. Gloves help keep the bugs off the hands to. No problem holding the bow and using the release.
and if it's really cold outside...I wear gloves to!
Rob
/ wearing gloves #64
I'm definitely a convert to wearing work gloves just about all of the time.
I hardly do anything outside the house anymore without wearing a pair of gloves. Having found gloves that fit tight without binding has a lot to do with it. I bought a pair synthetic leather mechanic's gloves at Sears for working on equipment in the unheated barn. They keep the hands cleaner, warm and cut down on the minor cuts and abrasions. Since then I found a pair of cheap synthetic leather gloves (Case promotional item) at the Kubota dealer for $8.00 that I wear most all the time (have to go back and get a couple spares) The synthetic leather gloves fit better than any leather gloves I've ever owned and the only time I think about leather gloves is when I need heavier protection, like welding.
I wish I had been wearing the leather gloves a few weeks ago when I got my right index finger crushed in the log splitter :eek: . Didn't break any bones, but it split the skin open, requiring 6 stitches and it's still swollen pretty bad :( . Heavy leather might have saved me the stitches. I don't want to know what the damage would have been if I hadn't been wearing gloves.
/ wearing gloves #65
I get 100% Kevlar gloves of various kinds on ebay and find them useful; they will take a brief stint at a 4" grinder without hurting you.
Also have $100 "Draggin Jeans" partially lined with Kevlar, got for motorcycle but most use was in church parking lot where I tripped and dore the denim but not the kevlar in the knee.
Mike
/ wearing gloves #66
I am getting better at wearing gloves (and Glasses) but I still do alot of stuff with the gloves on truck, instead of on the hands. Its funny though, let me catch my 23 yr old "little girl" doing any work with out gloves and glasses and I go off. I lose more gloves that way than any other.
/ wearing gloves #67
Wish I would have had my gloves on today.........Doing some metal cutting with a 4 1/2" grinder when it kicked back and walked up my finger.
/ wearing gloves #69
Gloves may have helped you from getting stitches but probably not from getting cut.
That .045 cutting wheel will go through gloves real darn quick, I have a small scar that reminds me of that fact.
/ wearing gloves #70
Gloves will not protect against a Hydraulic Injection Injury
Finger that has been lanced in attempt to save the finger and the hand. The injury was caused by a high - pressure injection of hydraulic fluid. If there is a pinhole leak in the hydraulic line and someone runs there hand along it, at 2000 psi, they can easily incur and injection of hydraulic fluid and may not even be aware that it happened until gangrene begins to set in. Use cardboard held above the line to check for leaks.
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
2019 DITCH WITCH FX25 PORTABLE VACUUM TRAILER (A59823)
2019 DITCH WITCH...
iDrive TDS-2010H...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
