wearing gloves
/ wearing gloves #21
</font><font color="blue" class="small">( if the chain is moving, both hands should be on the saw to avoid kickback. When taking more than 2 steps, the chain brake should be on. This will also virtually eliminate the risk of a glove being caught in the chain. )</font>
This is well said. How many times does your chain keep moving when it should be stopped when you are moving around. Some saws do not idle down fast enough, my Stihl for instance. It is very easy for the saw to catch on almost anything when you are moving. Stop the chain.
/ wearing gloves #22
Gloves are just like any piece of safety equipment or tool..if not used correctly they can do more harm than good, that's why there are so many different types of gloves.
Every style has their purpose.
I have and use several different styles for whatever job at hand.
/ wearing gloves #23
Just saw the new Stihl demonstrated that has the chain stop feature when the trigger is released. I originally thought this activated the chain brake, and didn't like it (nor did I opt to buy it on my new Stihl MS361 last year) because I thought it would be such a nuisance re-setting the chain brake each time to start sawing. But, that is not the case. Just pull the trigger and the chain runs as normal. Let off the trigger and the chain does not coast, it stops within a revolution.
Now I wish I had seen that, or realized it before I purchased the saw without this feature.
/ wearing gloves #24
</font><font color="blue" class="small">( Just saw the new Stihl demonstrated that has the chain stop feature when the trigger is released. I originally thought this activated the chain brake, and didn't like it (nor did I opt to buy it on my new Stihl MS361 last year) because I thought it would be such a nuisance re-setting the chain brake each time to start sawing. But, that is not the case. Just pull the trigger and the chain runs as normal. Let off the trigger and the chain does not coast, it stops within a revolution.
Now I wish I had seen that, or realized it before I purchased the saw without this feature. )</font>
Sounds like a Great Safety Feature. I will look for that on my next purchase of a saw. I have been looking to by a Stihl and with this Safety Feature on it gives me another reason to purchase that brand. Thanks!
Jim
/ wearing gloves #25
It was a safety problem. That's what I was trying to elude to with the acting before he thought part. He had just gotten some new leather gloves and a cob got hung up in an auger and before he thought about it he reached out to free it and the glove got caught in the auger. Since he was a large man he basically just was able to hold his ground while his arm was torn off.
Most of us know not to work around anything that is moving, spinning, rotating, etc. Everyone does something stupid from time to time and he just had a bad day.
I guess while operating a tractor or chainsaw I want to have my hands free without gloves so I can see exactly where my digits are. When you're using a chainsaw there really shouldn't be a need to have your hands near the chain, so it's just a matter of grip and vibration. It you have to service it or sharpen the chain I could see putting the gloves on since those little cutters are sharp. I would like to get some of those chaps though, Could definitely see that saving a leg if I had a skip.
For a tractor, I don't see any reason to use gloves unless it's cold out. I use them for plowing snow in the winter but that's about it.
The only time I really wear gloves is when I am loading wood (keep the slivers out) or working with fence (especially that intelliwire electric stuff, that'll cut right into your hand), livestock or dangerous material (fiberglass insulation for example). I just don't trust them around power equipment.
/ wearing gloves #26
I always wear gloves while working, unless the jobe is too delicate. Has saved me many cuts, splinters and blisters.
Ben
/ wearing gloves #29
Not to throw a monkey wrench into it,but how many who dont wear gloves have caught their wedding ring,THAT HURTS
ALAN
/ wearing gloves #30
Alan, I was just going to say that I am missing my right hand ring finger to to catching on the bulkhead of my flat bed trailer when I was an owner operator back in the 70's to mid 80's. Had I been wearing my gloves like normal I would not have caught it on the edge of the bulk head when I jumped off. Happened before I could think about it. Spent 4 hours in the ER. Had them take it all even the knuckle. They gave me the option to try to keep it but said it would never have the circulation and would be in the way. I don't even miss it now and most people don't even notice it. I don't wear gloves while working around my lathe or mill. But I do when working with the tractor. I also don't wear rings anymore.
/ wearing gloves #31
RE: "how many ... have caught their wedding ring,THAT HURTS"
My father lost his ring finger at the knuckle in a fall from a ladder. Tried to catch himself. His ring caught and stayed along with half the finger, the rest of him fell.
I think of that every time I feel my ring touch the rungs of a ladder. However, I am more afraid of losing the ring, so I never take it off :)
I think good work gloves prevent many minor injuries at the cost of a slight increased chance in causing major injuries around large moving machinery like ag augers and tractor PTO's. Probably not a lot of benefit to wearing gloves around table saws. As posted, I agree that they are not a good idea while machining metal but ARE a very good idea in sheet metal fabrication.
I agree with the other poster who mentioned that the glove will pull you in to a big machine and not get pulled off your hand. As they get pulled, gloves tend to constrict around your hand and wrist. Instead of losing some skin, your whole hanbd or arm gets pulled in. Also, you might not notice you are touching the moving machinery as quickly, getting more involved with it before you jerk your hand back.
I tend to prefer fairly snug fitting deerskin gloves. They wear out faster than cowhide or pigskin, but they stretch more to fit better and are still useful after they get wet.
Checmicals are something to really take precautions with. The skin on my left thumb has never been the same after having come into contact with some vinyl floor remover (MEK, I think).
Here in MN, you learn to work on vehicles and equipment without taking your gloves off in the winter. It is amazing how cold your hands get holding onto a metal wrench or touching a 10 deg F engine block. I can easily deal with nuts and bolts down to #6 or so with leather gloves on without a problem.
I have had the thought that NASA should recruit astronauts for space-walk repairs who grew up in cold climates because they would be experts at doing things with gloves on.
- Rick
/ wearing gloves #32
</font><font color="blue" class="small">( caught their wedding ring,THAT HURTS )</font>
The last time I wore my wedding ring, class ring, or any other kind of ring was December 29, 1965. That was the night my partner hit a tree head on with me in the right passenger seat. Someone at the hospital removed my rings before the swelling in my hands went to far, and it was over a month before the swelling went down enough that I could get either of them back on. And having known of people who hung their rings on various things, mechanics who caused electrical sparks with rings, etc., I decided they were not worth the risk.
/ wearing gloves #33
Wearing your wedding ring on your FINGER? THAT'S what I've been doing wrong!
All these years, and I've had mine through my nose. /forums/images/graemlins/crazy.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/wink.gif
/ wearing gloves #34
USAF disallowed rings on the flightline - never have worn one - wife bought me a fancy belt buckle instead - says "this doesn't come off unless I'm in the room - get it?" .... yes dear - got it. /forums/images/graemlins/smile.gif
/ wearing gloves #35
Sounds like this should be a thread on wether to wear wedding rings or not instead of gloves /forums/images/graemlins/smile.gif
I used to catch mine on stuff and eventually I had it taken down a size so the edge wasn't so catchy.
Just goes to show you that either way you are screwed. /forums/images/graemlins/smile.gif (talking about the gloves...) /forums/images/graemlins/laugh.gif /forums/images/graemlins/shocked.gif
/ wearing gloves #36
</font><font color="blue" class="small">( RE: "how many ... have caught their wedding ring,THAT HURTS"
)</font>
I haven't worn my wedding ring since a friend of mine that was in Technical College with me in Automotive Technicians Training got his had caught on a fan belt that broke while he was timing the vehicle engine. It was a freak accident that no one could have predicted but... none the less, it happened and it caught his ring and pulled him into the engine. It wasn't a pretty site to say the least. It mangled him for life. I love my wife but I will not wear a ring because I work on many things that it could cause problems with. Just isn't worth the chance.
Jim
/ wearing gloves #37
</font><font color="blue" class="small">( Wearing your wedding ring on your FINGER? THAT'S what I've been doing wrong!
All these years, and I've had mine through my nose. /forums/images/graemlins/crazy.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/wink.gif )</font>
/forums/images/graemlins/crazy.gif LOL... I figure a lot have. /forums/images/graemlins/shocked.gif /forums/images/graemlins/confused.gif You know... it can't be all that bad if so many say "I Do" still every day. I have been married since 1978... even though there are some hard times along with the good times, there's nothing like married life. Literally! But that's another thread.
I think that in a good marriage the two accent each other and make each other complete. Unfortunately it doesn't work out that way all the time.
Jim
/ wearing gloves #38
</font><font color="blue" class="small">( USAF disallowed rings on the flightline - never have worn one - wife bought me a fancy belt buckle instead - says "this doesn't come off unless I'm in the room - get it?" .... yes dear - got it. /forums/images/graemlins/smile.gif )</font>
Good Answer Mike!! /forums/images/graemlins/cool.gif /forums/images/graemlins/laugh.gif Also a good ideal except when leaning over your car fender without a cover on fender to protect it.
Jim
/ wearing gloves #39
I joke about being married, and all the trials and tribulations, but I can't (and don't want to) imagine NOT being married to my wife. I wouldn't be where I am today without her. We work together wonderfully. Life is good and she's the reason why.
I'll accept the risks involved with wearing the ring she put on my finger.
/ wearing gloves #40
</font><font color="blue" class="small">( I joke about being married, and all the trials and tribulations, but I can't (and don't want to) imagine NOT being married to my wife. I wouldn't be where I am today without her. We work together wonderfully. Life is good and she's the reason why.
I'll accept the risks involved with wearing the ring she put on my finger. )</font>
I mean NO dis-respect to my wife or any others. My wife and I talked about it before I decided not to wear my ring. It was a mutual agreement. She didn't want me hurt from wearing it and I didn't want to chance being injured while having children to take care of. We raised four children and now have a grandson. Being injured or mangeled isn't my Ideal of being able to enjoy life with my family. After we saw my friend get severely hurt with the freak accident, we talked and agreed that it would be safer.
Like you... being with out my wife would not be a lifestyle I would choose. She and I work together at all things and we have a very good life together. I can't imagine what it would be like without her. I don't particularily want to find out.
Jim
2014 Ford F-150 Ext. Cab Pickup Truck (A66736)
2014 Ford F-150...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2015 TECUMSEH BD (A67714)
2015 TECUMSEH BD...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
