wear does it go.
/ wear does it go. #1
herbie the lovebug
whites creek ,tn
john deere 170
i have a jd 170 lawn tractor. how& wear does the height adjustment spring attach, the lever is on left side &ankle high.
/ wear does it go. #2
What spring are you referring to? Is it the large 'Lift assist' spring? This is the spring that makes it easier to lift the deck from it's lowered set height position.
If so, one end is hooked to the frame near the front axle beam. The other end is hooked to the slotted link that connects to the lift lever.. The spring has significant tension, and is difficult or dangerous to install.
/ wear does it go.
no, its a small spring that attaches somewhere on or around a notched cam device that holds pressure on the mower deck height adjustment lever which is located on the lower left fender.
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
E-Ton Viper RXL-50 FOURWHEELER (A62613)
E-Ton Viper RXL-50...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
Frontier 3 Point 8ft. Sickle Bar Mower (A65640)
Frontier 3 Point...
