weak slow loader on deere 950
/ weak slow loader on deere 950 #1
Rackluster
Please help!
My loader is both slow and weak. Both functions on the loader are affected. I know nothing about hydraulics please walk me through troubleshooting this.
Couple things worth noting:
- there's a big dent in the hydraulic filter. Wondering if something could have broken loose in the filter and then blocked my screen?
- 3 point seems fine. I'm able to lift up a 5 foot heavy duty snowblower
- hydraulic control valve was replaced 2 years ago.
- I recently replaced two couplers because I had slow leaks. I put one of the old ones back on to see if maybe the new couplers were the problem.
Wht do you all think?
Thanks in advance!
/ weak slow loader on deere 950 #2
Change the filter and the hydraulic oil. Not sure if yours has a screen to be cleaned or not also, but someone else will chime in on that I'm sure.
Thanks guys. I replaced all the fluid, the screen, and the filter and the loader is nearly back to normal. It can't lift up the front of the tractor like it used to but it's night and day better. Wow that oil is expensive!
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2017 Case CX145D (A60462)
2017 Case CX145D...
CHEVROLET C-60 GRAIN TRUCK (A63291)
CHEVROLET C-60...
LOT OF PVC & PLASTIC PIPE (A63291)
LOT OF PVC &...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
