weak hydro cub cadet
/ weak hydro cub cadet #1
325bob
joppa md
cub cadet ztr50
I read all the posts on the weak left side Cadet rzts,which is what I have, what I cant understand is why the left wheel is strong, can't slow it with a pry bar jacked up, but when on the ground, very weak, I already replaced the trans. with a "like new"one only to have the same issue. any ideas?
/ weak hydro cub cadet #2
:welcome:
To the TBN forum Bob. We are glad that you joined.
What does Cub Cadet have to say about this problem?
/ weak hydro cub cadet #3
Did you replace the drive belt for the hydros, I’ve read that the left side pulley slips when the belt wears. And I would check the spring for the idler pulley FYI.
I tried a new belt, and actually moved the spring tensioner's anchor point for more tension, neither of which would explain why it works fine jacked up, but not on the ground?, update, I put some thicker oil in it, and it seems much better?, which still doesn't make sense?, I'm gonna put the same oil in the right side to try and replicate this anomaly? (it does have many hrs.1700!)
:welcome:
They just said the high hours meant it needed trannys.,they like money.
/ weak hydro cub cadet #6
Long shot, but worth checking. Make sure the pulley on the hydroshaft in not slipping on the shaft under load.
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
2012 Buick Enclave (A62613)
2012 Buick Enclave...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
