Loader Weak hydraulics
   / Weak hydraulics #1
WRENCH99A
Ford 1920 w FEL
I am (maybe!) fixing this unit for a church. It moves but just barely (engine is OK) and the bucket moves bt has no "oomph" (e.g. it wont lift the front end off the ground).
The hydraulic fluid (the reservoir is the transmission case) was contaminated with water, so we replaced the fluid and its filter. Negatioe results. There ARE metal crumbs in the filter.
Any ideas? I have no specific info or experience on this machine.
Thank you all!
   / Weak hydraulics #2
:welcome:
Finding metal "crumbs" in the filter is not a biggy in itself. One would expect to find them, as a result of mfg. and machining all those parts. But still may be a clue.
I'd suggest you make a plan to check the pressure at various points to determine what the oil psi is compared to what it should be. That will give a place to start (or stop).
Which NH might help get you some more expert answers.
Do you have good shop/tech manuals for this tractor?
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
