Loader Weak hydraulics
   / Weak hydraulics #1
WRENCH99A
Ford 1920 w FEL
I am (maybe!) fixing this unit for a church. It moves but just barely (engine is OK) and the bucket moves bt has no "oomph" (e.g. it wont lift the front end off the ground).
The hydraulic fluid (the reservoir is the transmission case) was contaminated with water, so we replaced the fluid and its filter. Negatioe results. There ARE metal crumbs in the filter.
Any ideas? I have no specific info or experience on this machine.
Thank you all!
   / Weak hydraulics #2
:welcome:
Finding metal "crumbs" in the filter is not a biggy in itself. One would expect to find them, as a result of mfg. and machining all those parts. But still may be a clue.
I'd suggest you make a plan to check the pressure at various points to determine what the oil psi is compared to what it should be. That will give a place to start (or stop).
Which NH might help get you some more expert answers.
Do you have good shop/tech manuals for this tractor?
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
71064 (A49346)
71064 (A49346)
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
2025 LandHonor UHA-16-3000G 2in Utility Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
