Weak brakes & battery box confusion.
   / Weak brakes & battery box confusion. #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
Noticed trailer brakes are weak.
Battery box says “recharge” on battery, but battery is only 2 months old and electrical tester reads 12.4V
Brakes work, but don’t do a lot, even with brake controller fully cranked to 10.
The trailer is only a year old and brakes worked well when I first got it.
What should I start looking at? Wiring connections seem fine
   / Weak brakes & battery box confusion. #2
little confused, power for brakes are supplied by the 7pin, connected to the truck, through the brake controller, the battery onboard is for emergency pin pull.
most trailer brakes are manual adjustment, have they been adjusted?
Yeah should have been more clear: there’s 2 issues
1. Battery box says “recharge” but tester says 12.4V
2. Brakes weak.
No, they haven’t been adjusted, but what would have changed that much from using it for a few months? It only gets used 2x per week. May have used it 15 times since I brought it home in March. The braking power dropped suddenly
   / Weak brakes & battery box confusion. #4
i don't know what a battery box is, your going to have to explain.
too tight brakes can get burned and wear quickly, other issue, is you had a grease seal leak, and the brakes are coated in grease, especially if they were greased using zerks and done improperly.
A trailer battery box is a small plastic box on the tongue of the trailer that contains a small 12V gel battery to actuate the brakes if the trailer becomes disconnected from the vehicle. It has “test” buttons you can push on the lid to provide information on battery status.
   / Weak brakes & battery box confusion. #7
well idk what voltage it deems rechargeable, is this battery charged when the 7 pin is plugged in? 12.4 is a touch low, not recharge low.
Trailer battery box.
   / Weak brakes & battery box confusion. #9
thats fancy, make sure its charging. plug into the truck with it running make sure its over 13 v at the battery terminals
   / Weak brakes & battery box confusion. #10
How do you grease an axle wrong with a zirc fitting??
If you just do 6 pumps of grease, fresh grease will never reach the outer bearing. There's a minimum of a 1/4 tube of grease capacity inside the hub between the inner and outer bearing on a 3500lb axle.
Excess grease will ooze out the outer bearing into the cap. So there shouldn't be much of a chance to build up enough pressure inside to force the grease past the lip seal.
I could see a failure if whomever installed the lip seal put it in backwards or lost the spring out of it.
But if the lip seal is installed correctly, then you can pump grease till your hearts content and it won't push past that lip seal and effect your breaks.
Honda ES 6500 Generator (A55973)
Honda ES 6500...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
HYD AUGER W/ 16" BIT (A52708)
HYD AUGER W/ 16"...
