We are making a pergola and a patio. Issues have begun.
   / We are making a pergola and a patio. Issues have begun. #1
JasperFrank
Ford 1220
Getting electricity to the patio and a fountain, IN MY SMALL BRAIN, everything has all gone to hell. I was going to use 1- 1/4 pvc pipe to run, in conduit, extension cords to the pergola, and from the pergola to the fountain. The entire feed to any thing out doors, was always GFI. There is no problem there. Everything, I come up with, as a solution is just too ugly, and non-code. I can't get, if i was to do it the right way, something that transitions this first pic into the second pic, which would be a pulled wire instillation and up to code. Have any of you ever seen an all weather cover that adapted an out door, horizonal outlet to a 90 degree junction to go under ground? I can't find one. I can't even find an extension off the existing box to add a down tube conduit to be in code. Is this just not a thing ever made?
I am attempting to go from this.
To this.
Since I don't need the outlets if they are on the pergola anyway. I can't find any sort of out door cover plate for the transition.
   / We are making a pergola and a patio. Issues have begun. #2
something like this and drill a hole to fit the LB into
is that code? :)
   / We are making a pergola and a patio. Issues have begun. #4
I think code would want you to have box extender by the same manufacturer, and as the extension is now in the elements, it would need to be enclosed. An inspector might let you off for a waterproof box mounted to an existing box, but I would doubt it, as that isn't the intended use.
I think to be truly at code, you would need to run romex from the outlet in the wall to an adjacent (surface mount) waterproof box that could feed your conduit and act like an LB.
An extension cord in a conduit is unlikely to meet code due to temperature heating of the cable, if the cable is even of a type that can be in conduit. I believe that you will need wires.
All the best,
Peter
   / We are making a pergola and a patio. Issues have begun. #5
I dont think that is not up to code but this one is
JPR, the local big box hardware stores have some thing like this but they don't mount to the existing outlet box, they mount using external side straps, and they are not pass through from the rear.
   / We are making a pergola and a patio. Issues have begun. #7
Sorry.
The one I referenced is an extension box. The entire back is open for access to the box it's mounted to. Mounted to the box with extra long device (or blank cover) mounting screws.
   / We are making a pergola and a patio. Issues have begun. #8
If it has to be to code, why not ask the inspector what he wants to see? When I built my barn, I had a question about code and called the city building department and asked them. They were quite helpful. They will, of course, expect to see their recommendations implemented when they come out for the inspection.
Found the extension box referred to JPR. Thank You! Found it at a much smaller ACE Farm Supply and Hardware store. This will work perfectly with 1/2 PVC and stll give me the exterior outlets.
   / We are making a pergola and a patio. Issues have begun. #10
You are welcome JasperFrank
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2022 KUBOTA SVL97-2 SKID STEER (A51242)
2022 KUBOTA...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2008 KALMER 4X2 SPOTTER TRUCK (A51243)
2008 KALMER 4X2...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
