JasperFrank
Veteran Member
- Joined
- Nov 23, 2018
- Messages
- 1,905
- Tractor
- Ford 1220
Here are the issues that are racking my brain. The original recessed box that is in the exterior wall is a brown, fiberglass like box. This box is not grounded. I have 12/2 romex with ground to this box and the wires feeding it are on a CFI circuit. This passed code inspection as an outdoor single gang receptical cause the receptical was grounded and the outdoor cover to the sockets was grounded through the central mounting screw to the receptical.
The extension box, is metal, and rated for wet locations, how ever, it has no apparent way to pig tail the ground wire to it. Even though the instructions say to use Green Grounding screws, which are not included. And even if I can do that, the blank cover then also has no way to be grounded cause the two cover screws are also acting as the way the extension is mounted to the wall box are not grounded. And of course there are gaskets that isolate each part.
Am I entirely screwed here?
