DFB
Elite Member
- Joined
- Dec 7, 2000
- Messages
- 2,923
- Location
- Southern VT, Southern ME
- Tractor
- John Deere 4100 HST /410 FEL, R4s
Thomas, WD-40 good stuff for sure. Used a lot of WD cleaning up the Zunny. Check out the pics. Before and after. (BTW the after was up at Gunstock for Vintage Race Day.)
One of the least things I do with it is use it as a lubricant. I usually use Zep 45 or tri-flow. There's also another spray I use has TEFLON in it. Can't recall the name right now.
Don't really find a need to use it on the H-D's. I use S100 Corrosion protectant on the metal/paint/plastic for storage. Other than greasing zerk fittings, wheel, swingarm and neck bearings, the cables are about it. I use a powdered graphite for the speedometer. One has a Kevlar belt, the other a pre lubed O-ring chain and I've used a parrifin wax chain lube for years after a few episodes of flinging oil up on the back/w3tcompact/icons/blush.gif of a certain p-pad rider./w3tcompact/icons/smile.gif
DFB
DFB
