Oil & Fuel Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor
   / Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor #1
jayste
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
It's an M4800 non-HST tractor. I've got 2 filters behind the right rear wheel against the case. I need to change it all. Any tips and suggestions?
   / Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor #2
Re: Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tract
My only tips would be to use a large Tupperware type tub to drain the 11.6 gallons of fluid in, and empty the tub out before it gets too heavy. I empty mine twice on a similar sized machine.
My suggestions would be to use Kubota oem filter(s), and stick with Kubota udt or sudt2.
   / Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor #3
I second the motion. You will probably be OK but if you make a habit of “extended drain intervals” use the best oil and filters available
Thanks for the responses guys. I'll be doing the service soon
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A56436)
Greenworks...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A57453)
2005 Volvo VNL...
2006 Ford Explorer Multipurpose Vehicle (MPV), VIN # 1FMEU73E36UA28575 (A57453)
2006 Ford Explorer...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2018 John Deere 1653 (A56436)
2018 John Deere...
