Oil & Fuel Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor
   / Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor #1
jayste
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
It's an M4800 non-HST tractor. I've got 2 filters behind the right rear wheel against the case. I need to change it all. Any tips and suggestions?
   / Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor #2
Re: Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tract
My only tips would be to use a large Tupperware type tub to drain the 11.6 gallons of fluid in, and empty the tub out before it gets too heavy. I empty mine twice on a similar sized machine.
My suggestions would be to use Kubota oem filter(s), and stick with Kubota udt or sudt2.
   / Way past due on changing hydraulic oil and filters on Kubota M4800 "geared" tractor #3
I second the motion. You will probably be OK but if you make a habit of “extended drain intervals” use the best oil and filters available
Thanks for the responses guys. I'll be doing the service soon
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
2370 (A58376)
2370 (A58376)
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
1793 (A58375)
1793 (A58375)
