Water temp gauge points south
/ Water temp gauge points south #1
SouthernSky
Platinum Member
Deville, LA
2013 Kubota L3200DT
When my Kubota L2650 came out of the shop for a new clutch, I found the water temperature gauge needle was inoperative. Instead of being between HOT and COLD, the needle was out of the range of motion, pointing downward.
The last thing I want to do is bring it back to these guys who redid my clutch to figure out what happened. All the connections appear tight.
Any ideas?
/ Water temp gauge points south #2
They may have started the tractor without the sensor hooked up, when you do this there's nothing to provide a "load" for the circuit. I did this with an '85 Chevy truck I owned, the dam*ed gas gauge never worked right after that.
Sean
