Water Pump Voltage - 230 vs 115 Single Phase
/ Water Pump Voltage - 230 vs 115 Single Phase #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
My gas generator will provide either 230@20-amps or 115@30-amps. Should I go with a 230 or 115 pump? Does it matter and why? Pump will be used with a large water tank mounted on a trailer for remote irrigation and burn control. TIA
/ Water Pump Voltage - 230 vs 115 Single Phase #2
It will draw 1/2 the current at 220v, so you can use smaller gauge wire. It will most likely start easier at 220v as well.
/ Water Pump Voltage - 230 vs 115 Single Phase #3
Your generator will also only use half the windings at 115 v. and the coil will heat worse. If you have the option, always wire motors to run on 220-240v. They start faster, run cooler and last longer. A generator will be more efficient feeding a 240 v. balanced load, and will provide nearly twice the power.
