Water pump on mf135 continental year 1967
   / Water pump on mf135 continental year 1967 #1
Tpiton
Gaspe
mf135 1967 gas engine
Hi folks, I have a neewbie question. I have a 1967 mf135 gas engine. I notice a quite bit of slack on the spindle that has the cooling fan on. I've done a little research, i found out that it's the water pump pulley. Do i need to change the water pump or is there a bearing to change between the pulley and the pump ? Can i take the shaft off the pump ? it's sold seperatly
the new water pulley would be this part. How is put together on the pump
or do i need to by this ?
   / Water pump on mf135 continental year 1967 #4
If yours is the original, no telling when the seal would go. Buy the new one and install.
don't know if't's the original. How much of a job is to change the whole thing with the pump versus changing the pulley ?
   / Water pump on mf135 continental year 1967 #6
I've got a '67 135 with Cont. engine....and yes, I changed out the water pump....It is the same amount of work/disassembly of the tractor no matter which..so just do the pump/pulley together....you will note that the pulley (as well as I remember) is pressed on...so get it all together at the start...
i just need to remove the radiator and everything look accessible right ?
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
Electric Concrete Mixer (A51573)
Electric Concrete...
