water pump leak
   / water pump leak #1
millerweld
oswego ny
mahindra max 28 tlb
hello everyone !!!!
New to the forum. I did a lot of research on this site before I bought my Mahindra Max 28 TLB package. Tractor has been bitter sweet. I done a couple jobs since I took delivery in March. However I had a loader valve leak and a bad bucket cylinder. Both were fixed under warranty. I used it for a few minutes the other day. Now I have antifreeze leaking from weep hole on water pump. I will be on the phone to dealer tomorrow. This tractor sat around for a while it was last years left over. I think this a result of that, I hope.
Looking forward to being a member on the the forum thanks
   / water pump leak #2
That's irritating but lean on your warranty and chances are you'll get all the bugs out before it costs you money. Welcome to the forum!
   / water pump leak
The mechanic stopped out to look at water pump. Should be picking it up tomorrow.
   / water pump leak #4
hello everyone !!!!
Welcome to TBN--join the fun:thumbsup:
I have a leaking water pump (shaft seal) on my 1951 Minneapolis Moline BF tractor that I'm restoring. Rebuilt that pump about 3 years ago. It sat on the shelf since then while I slowly moved ahead on the restoration. Installed the pump last week. Adjusted the belt tension. Bumped the starter a few times to check for belt wobble. Got fairly large leakage from the weep hole. I figure that the part of the pump casting on which the seal is located probably has some corrosion that's causing the leak. Found a rebuilt replacement on the Web for about $80. Should be here next week.
Good luck with your Mahindra.
   / water pump leak
water pump fixed:););) Dealer came and got tractor the day I left for vacation and it was in my yard the day I got back!!!!
   / water pump leak #6
Cool, glad to hear you got it fixed.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53473)
2017 Yale GLC050VX...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
