water problems
   / water problems #1
druster
I have an area about 50' x 20' where water sits in the spring or after heavy rain. 3 surrounding properties slope in this general direction and it is the lowest spot on my property. ( so regrading the water away is not an option)
I have thought of 2 ideas and want to know if anyone can add to them or suggest a better option.
1. Dig out the whole area a foot or two in depth, replace with clear gravel, fabric and top dress with top soil.
2. Sloping grade toward Some kind of french drain / culverts, four or five feet deep, 3 or 4 feet wide.
Any help would be appreciated! Thanks
   / water problems #3
Thats right,you know that saying about lemons,right?
   / water problems #4
Does the water have any place to go? A french drain would divert the water to a place that is lower if such a place exists. It sound like you have clay soil so putting in dry wells of gravel would only work until they fill up with water since water does not soak into your ground very fast.
Regrading with additional soil so that the water would not stand there may be option. Good luck Rick
   / water problems
Thanks for the help, a pond sounds like a lot of work....the water has NOWHERE to go and drains very slowly. So.....
   / water problems #6
Hi,
Well here the country there are lot of area where the water problem is going day by day increase the reason is that pollution which make water bad and can not able to use.
   / water problems #7
There are enough pond threads on here that turned out pretty good. You can call that your little nature sanctuary. The one issue might be not making it so deep that it could be a liability if someone fell in. Downside of some ponds might be attraction for mosquitos.. Which could attract birds...
   / water problems #9
Boy, you know what I love about this forum. When I get a problem and plan on posting a question, somepne else has the same problem.
I have three properties draining thorough mine towards a storm drain. During a heavy rain it is a small creek. I found a soft spot about 250' behind the house and started digging a trench. I found a spot about 1 foot down that was draining into my trench. I dug in that direction, more water. After about 70 feet of trench, 3 ft deep, I decided to take a break. I came back an hour later and the trench was FULL of water. I dug a big pit besides it and filled it with rock then extended the trench to the pit. Holy smokes, talk about running water. I back filled and dropped another couple of yards on it. I think I may have to trench it to the road, about 350 ft of trench.
   / water problems #10
druster,
How high is the next lowest place, and if it could drain there would it have any place to go.
If you are stuck with the layout, you could install an automatic pump to a small drain in the middle to pump and keep it dried out most of the time. Maybe even a windmill pump.
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2012 DRAGON 200BBL ALUMINUM TANKER TRAILER (A53843)
2012 DRAGON 200BBL...
