Water in YM1500 steering box
/ Water in YM1500 steering box #1
KidYanmar
I went to use my 1500D this winter to move some snow, the steering wheel would not move.The front axle was checked and one side rebuilt last year so I ruled out a problem there,if you see the post for that,tractor had alot of water problems.After heating the steering box with a heat gun and the steering is working.
I pulled it in garage,removed fuel tank and plug for steering box.Light brown fluid came pouring out,looks like 90w gear oil mixed with water.
Pulled the steering wheel off and could see the a seal under the steering wheel is alittle worn.It looks like one peice and is held in place with rubber plugs on two sides of the steering collum.
How can I replace this seal?
/ Water in YM1500 steering box #2
Don't really have a good answer for you, but this drawing might help you. I can't see any rubber plugs in the drawing. Looks like #3 would have to be pulled out and then #6 which is called a bushing but looks more like a seal to me. Yanmar Tractor Parts: STEERING_EXTERNAL
Thanks for your reply winston1,I have that diagram in the Japanese parts list that I have.What is #3 on my tractor seems to be one peice of rubber part is on top of collum with steel washer on top, seal built in center,part inside collum held in place with two plugs that go thru two holes on the side of collum.Seems very difficult to remove and even more difficult to find a replacement.
/ Water in YM1500 steering box #4
The two little rubber parts are actually made into the bushing. They will pop into the holes when you replace the bushing and seal assembly. To get it out you have to push like crazy on both of them until they clear the steering column. Usually tears them up getting them out.
I've had to take my steering apart twice now to remove the water that settles into the bottom of the worm gear housing. Poor design IMO. No way for condensation or rain water that gets in to get out.
The latest solution I have read is to remove the water and then pack the entire gear housing with grease when you get it put back together. It's a bit of a pain to take it apart and get everything lined back up. You will have the most trouble getting the bottom of the steering shaft to slide into the lower bearing correctly or it will bind the bearing and you will be able to tell as the steering wheel will be hard to turn.
/ Water in YM1500 steering box #5
Unless you have excessive play in your steering column shaft I wouldn't worry about replacing those bushings. NOTHING, other that covering the steering wheel, will keep water out of your steering box if you store your tractor outdoors.
Thanks for your replies, they are a big help.I put a small lenght of tubing on the tip of a jug of 80-90w gear oil and filled the steering gear box slowly with oil from the bottom,forcing the old oil out the top.The bushing/seal at the top of the collum must be as difficult to take out as I was thinking,If I got it out it would not be useable.The seal on the bushing/seal has some places where it is split but very small.I could see how water could get in if stored outdoors.I will put everything back with the new oil in the gear box.I will try and find the part before I go further and store it out if the weather.
The steering worked after I put everything back untill it got cold again.It froze up solid again.I removed all the same things as before and the dash.I removed the steering box and could see why the quick fix did not work.The steering box is not flat on bottom but has a pan under it like an oil pan on an engine that was full of water.I have it upside down now with the water draining out the fill hole.
/ Water in YM1500 steering box #8
I can always tell when mine is starting to fill with water. Oil will start seeping out around the top of the bolts at the box. This time when I drain it, I'm going to see if I can drill a small hole and install a valve. Then I can just drain the water out and the oil should settle back down into the bowl. The other option is to pack the whole box with grease.
/ Water in YM1500 steering box #9
That is the way that mine is and has been since I bought it 4 years ago--Full of grease. I think that there is a bit of water in there too, but I try not to let it sit in the weather much. I do not have a nice heated place for it, but I do have a roof.
Mike
I was wanting to drill a hole to drain water on the bottom of the steering box but the bottom sits inside the housing between engine and tractor.The housing is cut out if you look in there the steering box is above the throw out bearing for the clutch and drive shaft.I would not want any oil to get in there,there would be no way to get at plug anyway.If a plug was installed on the upper part of the steering box,water would not drain from the lower part.When I removed the stering box/steering collum and turned it upside down alot of water came out.
/ Water in YM1500 steering box #11
It's been a couple of years since I last took mine apart and thinking back now I remember why I didn't put the tube in the last time. It is how you describe it. I would have to drill a hole in the bottom of the bell housing and run a tube down to the hole. It's time to drain it again and this time I am going to just pack it with grease and look at putting a small drain hole above the steering box in the shaft to let water drain out above the grease. Hopefully that will work.
/ Water in YM1500 steering box #12
Had a problem with water getting in my steering box about 6 years ago. Clean it out and found that the water was getting in at the nut where the steering wheel connect. Seal the area and system is still bone dry.
/ Water in YM1500 steering box #13
I put in a new top seal and the steering shaft rubber seals and it still gets water in it. I even sealed the cap on the steering wheel with silicone. I think it is from condensation in the steering tube. I'll see how much water is in it when I take it apart in a few days. Maybe I'll get lucky and won't find any but it's showing signs of water pushing the oil up the steering tube again.
/ Water in YM1500 steering box #14
Mine didn't have a cap over the nut. I took a cap from a spray paint can and it is a prefect fit, been there for 6 years.
/ Water in YM1500 steering box #15
The only way I have found to tell for sure if there is water in the bottom of the gear box is to take it apart. The first time I took mine apart was because the steering felt a little stiff one day. Found the bottom bearing retainer had completely corroded, the ball bearings were laying in the bottom and the box was full of water.
Is there another way to tell if it is filling up with water?
If you said that gear oil was coming out hole on the side of steering collum,that is what mine was doing because of the water in it.You could check to see if water is in the steering box by the color of the gear oil in it.When mine had water it was light brown not dark like it should be.
/ Water in YM1500 steering box #17
Mine starts leaking oil out around the bottom of the steering column where the 4 bolts attach it to the box. Probably the seal is not sealing completely. That's usually the first indication that it is filling up with water.
/ Water in YM1500 steering box #18
hello
i put a grase nippel in the hous and pumpt it full grase thil the top of the pipe
i heave no troble any more
wen the writing is not correct i am sorry
from Holland
/ Water in YM1500 steering box #19
hello
from Holland
When I drain mine again I am going to fill it with grease also. That seems to be the latest method that works on the ones that tend to get water in them.
thanks for the update.
/ Water in YM1500 steering box #20
Mine does not get water in it, although it has not been rained on in the 10 years that I have owned it.
2022 Ford F-150 Pickup Truck (A61568)
2022 Ford F-150...
(INOP) YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A62129)
(INOP) YANMAR...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
