Tires water in tire question
   / water in tire question #31
You can also fill a bottle (that can hold tire inflation pressure) fill it with antifreeze and attach it to your tire, held upside down. Then attach the air compresor to it, with an air hose port on top of the bottle. Because the water is heavier than the air /forums/images/graemlins/smirk.gif it will stay at the bottom of the bottle and leave through the low port into your tire when the compressed air forces in.
Kinda like a vacuum manure tanker idea /forums/images/graemlins/grin.gif
I do not use tire ballast because it increases the fuel consumption on all the other jobs where the extra weight isnt needed.
I do use a big 2 meter earth scoop as 3pt hitch ballast when doing heavy work with the front loader. Because the center of gravity of this +/- 1500 kg of 3pt hitch ballast is behind the rear axle, it even unloads the front axle for about 750 kg making its life a little easier /forums/images/graemlins/smile.gif
Case 580D (A47384)
Case 580D (A47384)
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
