Oil & Fuel Water in my fuel
   / Water in my fuel #1
Kchamberlain
Dunnellon, Florida
John Deere 1050
I added some fuel in my John Deere 1050 that had some water in it, I drained the fuel tank and cleaned out the filter. It still won't start what else do I need to do to get her running again.
Thank you
Kchamberlain
   / Water in my fuel #2
were you able to prime the system? I don't think your deere has an electric lift pump but sometimes there is a hand pump fitted near the fuel filter. Did you fill the fuel filter as much as you could? Sounds like you may have air in the system. There is definitely a specified way to bleed the air out of the system in your deere.
Also is this a cleanable filter or is it a spin on that needs to be replaced?
   / Water in my fuel #3
Did old filter get any water in it? If so filter will probably require replacement as most water soaked filters block fuel flow.
   / Water in my fuel
It's a filter that can be replaced very small one inside a plastic cup type. I don't know how to prime the system or get the air out is there any one out there that can help.
   / Water in my fuel #5
I had a 1050 several years ago and as I remember the fuel system was gravity fed..no fuel pump. At the location where the fuel filter is, there is a fuel shut off and three bleeder screws. With the shut off in the open position open the screw to the left to bleed the line from the tank to the filter housing until you get fuel with no air bubbles then close the screw. Next open the center screw which will fill the filter housing with fuel pushing out the air. When you get fuel and no air bubbles close that screw. There should be a bleeder screw at the injector pump which also needs to be bled. After bleeding out these locations the engine should be getting fuel with no air in the system and should start. Let us know.
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2019 Challenger MT738 Track Tractor (A53342)
2019 Challenger...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
