Water heater - how hot is too hot?
   / Water heater - how hot is too hot?
RonMar said:
I bet he has a lot of available heat from the boiler, and with the right exchanger it could have an acceptable recovery time. and I agree, the heatex, fittings and a on/off thermostatic control valve could probably be had for much less than a tank of fuel.
Thanks to all who provided good advice. I've definitely got adequate heat transfer, just looking for the best way to regulate it.
I'm looking for a simple temperature operated valve that will close at approximately 160F and open below that. I could do it with a motorized valve and aquastat, but would prefer to find a simpler, mechanical valve. One of the earlier posters eluded to something like this being available, but I haven't found it yet.
I've also read about "wax" valves, where the heat expands the enclosed wax and closes the valve, which then opens again as it cools.
   / Water heater - how hot is too hot? #32
McMaster-Carr, they start at $450.
   / Water heater - how hot is too hot? #33
You can probably beat that price a bit using a solenoid operated valve and a thermal switch sensing tank temp. I just did a quick look at the McMastr website and the 2 parts I think would work could be had for around $250. there might be less expensive combinations available there or elsewhere also.
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2016 Toyota Prius Hatchback (A55758)
2016 Toyota Prius...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2017 Ford Explorer AWD SUV (A55758)
2017 Ford Explorer...
