Water heater - how hot is too hot?
   / Water heater - how hot is too hot?
RonMar said:
I bet he has a lot of available heat from the boiler, and with the right exchanger it could have an acceptable recovery time. and I agree, the heatex, fittings and a on/off thermostatic control valve could probably be had for much less than a tank of fuel.
Thanks to all who provided good advice. I've definitely got adequate heat transfer, just looking for the best way to regulate it.
I'm looking for a simple temperature operated valve that will close at approximately 160F and open below that. I could do it with a motorized valve and aquastat, but would prefer to find a simpler, mechanical valve. One of the earlier posters eluded to something like this being available, but I haven't found it yet.
I've also read about "wax" valves, where the heat expands the enclosed wax and closes the valve, which then opens again as it cools.
   / Water heater - how hot is too hot? #32
McMaster-Carr, they start at $450.
   / Water heater - how hot is too hot? #33
You can probably beat that price a bit using a solenoid operated valve and a thermal switch sensing tank temp. I just did a quick look at the McMastr website and the 2 parts I think would work could be had for around $250. there might be less expensive combinations available there or elsewhere also.
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
(INOP) JOHN DEERE 670B MOTOR GRADER (A51406)
(INOP) JOHN DEERE...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
