kenmac
Super Member
- Joined
- Feb 13, 2005
- Messages
- 9,839
- Location
- The Heart of Dixie
- Tractor
- McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
I also wonder about the high temperature cutoff in the regulator itself. I can't find any documentation of what mine is set for. It's a Robertshaw propane regulator, and have read that these don't self reset once they trip. So, I want to avoid activating that safety device by having the water in the tank too hot.
That high limit you are talking about is a small wire that's under the thermocouple. It runs inside the thermostat bulb in the tank. I have had some to reset & some won't .You would have to try to relight the pilot to see if it will relight ( after the water cools down) to know if it will reset or not. It should cut out some where around 180-190 deg.(this would be higher on some commerical tanks) water temp. It only shuts the gas burner off to the W.H. Most people don't do it .But, the maker of the T& P valves state that the valve should be manually operated about every 3-6 months to make sure it is functioning properly (not sticking) I wouldn't want to go over 180-190 deg.tank temp. Some T&P valves will began to open at around 200-205 deg. even though it's rating states 210 deg.If the control knob is turned to HOT. The water temp should be 160 deg per robertshaw. Perssure & temp is something you would want to keep to within or under the safety devices limits
