Water conditioning and treatment
/ Water conditioning and treatment #1
stl
Missouri
JD 2305 - sold
We built a new house but used the well from the old house that was still working fine. The well was serviced, and a new pump installed, etc.
Problem is that the water is very, very hard and has iron in it.
Any recommendations for water conditioning/filtration companies, products to look at (also to avoid)?
/ Water conditioning and treatment #2
Culligan.
I have had one for 35 years. The one we have now is much more economical to run than the old ones were.
/ Water conditioning and treatment #3
We just got rural water a few months ago but before that we were on a well that had good water but was somewhat hard. We had a whole house water filter, and after that a regular water softner. The water softner is the kind you add salt to, maybe 40 lbs a month or so. It works well, is simple to run, and other than adding salt, pretty much maintance free. The filter I changed maybe once a month. After several years I know you have to change the media in the softner. When we got the rural water, I did away with the water filter system but was advised by the rurarl water company to leave the softner in place.
/ Water conditioning and treatment #4
Sounds like my water.
Our house was 7 years old when we got it; all the sinks, toilets, dishwasher, were iron stained. The people living here used bottled water for drinking.
Immediately after moving in, we got a Rainsoft unit. Pre/sediment filter, then commercial grade softener because the water is so hard. In the kitchen, we also have a reverse osmosis filter. It worked for about 15 years, with a couple minor issues. The RO is still working fine(with regular filter maintenance ect).
When the Rainsoft softener went out, we changed to Kinetico. I like this unit better. It is two tank; when one tank is flushing, we have good soft water on the second tank. It is mechanical, and based on water use, not just a timer.
I like this unit better. It uses less salt, on demand as compared to timed; timed regenerates whether you need it or not. And, the neighbor has had a Kinetico for 28 years. With no issues, same hard iron water.
First thing I would do, is have your water tested to see just how hard it is... That will help you with figuring how many grains of softening you need. We, needed a lot.....
/ Water conditioning and treatment #5
I have done landscape irrigation off and on for a few years now. It never ceases to amaze me how much sediment there is in piped water systems. I always put incoming filters on everything. Spray heads clog, and drip, well, clogs worse. Easier to service a filter.
/ Water conditioning and treatment #6
A gas hot water heater makes for an excellent sediment tank and saves on filter changes. All the pipe connections needed are there. As for maintenance, open the drain a couple of times a year. Your mileage may vary.:D
/ Water conditioning and treatment #7
We have had an Iron problem for years, turn the inside of the dishwasher red, as well as the toilets, I have bought now 2 green sand filters from granger over the years, they back flush, with no salt. I worry about putting the salt into the creek. The green sand has to be "cleaned" every few years, and I just find a couple of strong friends to tip the tank over and lay it out in a kids swimming pool, and clean it. I just checked grangers website, and did not find one, but they will take care of the iron. These used to cost around 5-6 hundred bucks, but again no salt, and very little ongoing costs. Oh also, you need to introduce air into the system before the filter for them to work, and you may want to put a air bleed after to keep the stuff in the house from burping. I did away with the latter, as they I found that they are a PITA in the pump house.
Has anyone had Sears or Home depot install a water softener and filter setup, and how dies that compare to the high dollar national chains like culligan.
/ Water conditioning and treatment #9
My only experience was with Rainsoft - They did fako tests and high pressure sales. I eventually had to demand that the salesman leave. Similar systems available locally were a fraction of their "one time deal" price of $6000 for a water softener. The lifetime guarantee only covered the resin.
This web site seems to have sensible info and pricing but I have not used them personally.
Water Softener Systems, Iron Filters, Water Treatment Systems for Home or Business.
/ Water conditioning and treatment #10
You need to have your water tested to know how many grains of hardness you have, and if there is anything else you have to treat for. That, will give you the information to figure how many grains of softening you need. With my bad water, we needed a LOT more than what a Kenmore or HD unit could provide.
You won't know what you need, till you know what you're dealing with. Sometimes you can get your water tested at the county offices, for a fee.
/ Water conditioning and treatment #11
We originally had Rainsoft. Their prices were ok, service was good. Had to have extra water tests; our hard water overwhelmed the little kit the salesman used. It was easy to tell it was over his head...
/ Water conditioning and treatment #12
I have the same setup. The Kinetico is a very care free softener, and if you are using softened water, you will have to have a reverse osmosis system for drinking water, or else you will have to distill your water. I don't care for the softened water without further treatment.
I met with the kinetico salesperson today, and the softener along with an RO unit was $3800 installed. Yikes, getting more and more expensive.
Good price, bad price?
/ Water conditioning and treatment #14
/ Water conditioning and treatment #15
As a Certified Water Technologist and over 22 years experience in industrial water treatment, the best place to look is the Association of Water Technologists website and find a member in your area that will test your water and make a recommendation for a softener and filtration. They may or may not charge for the service and their company may or maynot sell softener and filter systems. next best is the county extension service or county health dept. and ask for testing and advice and recommendations of an indepent lab.
Depending on test results you may only need a simple softener, if you use a lot of water and the water is very hard also, you may exceed the "grain capacity" of a single tank timer controlled unit, and need to go to the twin tank water meter control unit. If your TDS "total dissolved solids" are more than 500 ppm you almost have to put a 20 to 50 micron filter before the softener to prevent solids or sediment from clogging the resin bed in the softener and reducing its capacity. If you have sulfur or iron taste you may need a chacoal after filter.
If you have a high enough iron content ie;"the iron is staining things", then you will need to use a salt with an iron cleaner in it or a separate iron cleaner additve. Other wise the iron will attach to the resin and prevent the ion exchange from taking place, the normal regeneration process will not remove the iron once it's attched.
Sears and Graingers both have good tech help and explanations of softener systems in their catalogs ,on line and on the phone, how to test, how to calculate and size a softener, along with filter systems. Again I still recommend a professional be consulted.
Good luck, if you need more help PM me. Joe
/ Water conditioning and treatment #16
PS;
Also talk to local people and see who they recommend, check with local plumbers and well installers, they may be pretty knowledgeable of local conditions and be reasonably priced.
But always get more than one source/price.
Joe
/ Water conditioning and treatment #17
Sounds like great advice. All i know about this is a house i worked on last year. The owners put in some kind of high end ion exchange gizmo with ultraviolet prefilters...the whole shebang. cost him 1000's.
The water still came out brown and smelly. Id advise low tech tanks and salt, with a bypass for landscape plants (they hate the salt) and an RO system for icemaker and drinking.
So oddly, our water is NOT high in iron. Yellow staining in toilets is actually thick mineral deposits that do come off with scrubbing.
We had the water tested, and it was 36 gpg of hardness. They told me that was high. The kinetico was installed and there is a noticable difference.
Yamaha Golf Cart (A60352)
Yamaha Golf Cart...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2007 Volvo C70 Coupe (A61569)
2007 Volvo C70...
2017 Ram 3500 Flatbed Truck (A61568)
2017 Ram 3500...
2025 Pabreak 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2006 INTERNATIONAL L9227(INOPERABLE) (A60736)
2006 INTERNATIONAL...
