wash down
/ wash down #1
cabin kioti
Sullivan County Pennsylvania
ck 30 hst
I have a 2006 ck30 fel bh. I have pressured washed the tractor and attached equipment but never the engine. I was wondering if anyone else has washed down the engine and with what product. Thanks all.:thumbsup:
/ wash down #2
I've always washed the engines in all my motor vehicles, including motorcycles and tractors. Sometimes, just water, sometimes spray on a detergent first (Simple Green in more recent times), depending on how dirty it is. Then I blow off any excess water with the air hose, and run the engine until it's thoroughly warmed up and any remaining moisture has evaporated.
/ wash down #3
May want to cover/slip plastic bag over breather intake.
/ wash down #4
I also clean my tractor engine, I cover the air intake and spray it down with Full strenth Purple Power let it sit 5 minutes then use the pressure washer to take the grime off. I then run the engine till its dry.
/ wash down #5
Are you familiar with where the electrical components are located on the engine? Where the fuse box is? The relay panel is located? If you answered no to either of the questions, do not spray water under the hood. If you do know the locations of the items in the questions and decide to wash the engine STAY AWAY FROM ALL ELECTRICAL COMPONETS, FUSE AND RELAY PANELS WITH WATER.
/ wash down #6
I would not use a pressure washer on my engine. If you force water somewhere it does not belong you will wish you had not used a pressure washer. I would warm up the engine, but not till its hot, and then spray on the cleaner of choice and hose the engine off carefully and without getting any water on sensitive electrical relays, etc., as has already been mentioned.
Once completed I'd use an air hose to blow dry the important areas and then run the engine until completely dry.
Then I'd finish with 7 coats of wax!:laughing:
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
Hydraulic Breaker Mini Skid Steer Attachment (A64553)
Hydraulic Breaker...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
