Was almost the perfect day mowing , till it wasn’t.
   / Was almost the perfect day mowing , till it wasn’t. #1
Mud2Money
Michigans thumb.
LS MT573CPS, NH TC45DA , Case SC
Ah the joys. Win some , loose some. Job still made money at the end of the day.
Got a job for a 4.2 acre field. First time cutting it. Took it easy. Cut the whole field but left a high area by a bean field. It had combine ruts and a few v ditches.
Went to take a final pass and cut lower by the beans. Well we’ll, looks like someone found some boulders I then found. A average large pumpkin size Boulder lay in a v ditch awaiting.
Soon as I heard the hit I lifted , but apparently so did the Boulder. This son of a gun juggled in my blades till I shut the pto down. Then just plopped down and rolled out the side.
Results , broken blade , tore up deck, profits loss.
New set of blade and a little welding. We will be back to beating this thing up some more.
   / Was almost the perfect day mowing , till it wasn’t. #2
Brush hogging a new property is always the same... "There's nothing in that field".
I cleared an old 5 acre field some years ago for a neighbor's commercial construction job. The disgruntled man from across the road peppered the field with cinder blocks and rebar. Fortunately I saw the first few, and cleared it all out with the loader, and the contractor (neighbor) loaded it all up in a dump trailer and dumped it in the disgruntled man's front yard.
Sorry to hear of your incident.
   / Was almost the perfect day mowing , till it wasn’t. #3
OUCH! rocks are hard on steel!
Fresh set ready to beat up. Yep always the same it’s clean. I get a lot of jobs in the city by me. I’ll be darned if every home from the 80s back didn’t come with out it’s own garbage dump.
   / Was almost the perfect day mowing , till it wasn’t. #5
Yup lot been there...just one more pass,one more trip hauling wood trailer full on soft ground. :(
   / Was almost the perfect day mowing , till it wasn’t. #6
Before I had a trash pump I used my snow blower on my Ford 1700 to dewater a pond. You would be surprised how well this really works.
One year I just backed a little too far out into the pond. I found how deep the mud was when I tried to motor out. Took the better part of an hour and a half to extricate with a hand come along.
   / Was almost the perfect day mowing , till it wasn’t. #7
That's the most bent blade I've seen.
   / Was almost the perfect day mowing , till it wasn’t. #8
Ouch!
Thanks for reminding me that my blades need to be sharpened.
   / Was almost the perfect day mowing , till it wasn’t. #9
I cut a new field this year. Tall weeds hid a big chunk if concrete. I was sure glad I had taken the old mower with the chain conversion. Chains tolerate rocks pretty well.
   / Was almost the perfect day mowing , till it wasn’t. #10
Well, it's a little late now, but I never cut with out having my bucket down or my grapple. Even on fields I've done before. If I can't see the ground I don't trust what's there.
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A51572)
1999 Volvo VN...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2012 Ford Fusion SE Sedan (A50324)
2012 Ford Fusion...
2015 FREIGHTLINER CASCADIA(INOPERABLE) (A52472)
2015 FREIGHTLINER...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
