Warranty Question!
/ Warranty Question! #1
GreenLaw
Bowling Green, Kentucky
I received my Kubota Grand L3130 with FEL less than two weeks ago. I noticed afew days ago, that I have a hydrolic leak around one of the FEL fittings. My question is this: Is the leak covered by the warranty? or How hard is it to fix it myself? I have never messed around with the hydrolic system. It doesn't look that hard, could I just unscrew the fitting and try placing some tape around the threads? Thanks for your attention. James
/ Warranty Question! #2
Probably all you need to do is tighten the fittings. My B7800 had a few leaks develop after the first couple of hours. A little bit of oil is all it takes to make a big mess.
/ Warranty Question! #3
Most don't recommend the tape but mine was assembled with plenty. I wouldn't be too concerned on contaminating the hydraulic fluid but I'd use it sparingly. It do stop leaks. Simply tightening is usually enough though.
/ Warranty Question! #4
I had the same thing happen. My dealership is quite local so I took the tractor back and the leaks were stopped right then..... no charge. It must be normal at first for to have a few leaks. I would be careful not to over tighten them or twist a line. I have had no more leaks in over 50 hrs.
Good luck!
/ Warranty Question! #5
The BH on my 3130 had a couple leaky fittings. I tightened them a little and no more leaks. It should be covered by warranty but if you can turn a wrench, it would be alot easier just to much sure the fittings are tight before going to the trouble of taking it in to the dealer or having them make a house call. Dont torque on them too hard, snug and 1/4 turn should do it.
Thanks everybody for providing me with alittle help. I have to work tomorrow, but I will try to carefully tighten the fitting. I hope that will take care of it. It hasn't leaked abunch, but it really conserns me. Thanks again. James
/ Warranty Question! #7
If you do remove any hoses or fittings,make sure the pressure is relived by having your bucket on the ground. Noboby wants to take a hydraulic oil bath or be injured by a falling loader. Norton
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
(INOP) 2013 KAWASAKI MULE 4010 UTV (A64280)
(INOP) 2013...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
4' 3pt Disc Harrow (A64119)
4' 3pt Disc Harrow...
2022 John Deere 7R 210 Tractor (A63111)
2022 John Deere 7R...
HURRICANE (10) DRAWER (A64280)
HURRICANE (10)...
