Warning- short circuit possibility
/ Warning- short circuit possibility #1
DiskDoctr
Platinum Member
Western PA
Mahindra 3510
Doing some maintenance today and finally decided to take a look at why my horn and front lights didn't work, and found a blown fuse.
So I started checking the wiring and found this short in the piece of wire connecting the left front headlamp to the wiring harness.
It rubs the edge of the air filter housing (see pic) and wore through the insulation, creating a short and blowing the fuse.
I removed the short section of wire and all is well. I will repair the wire and put it back in, along with a little creative wear protection. Haven't decided what yet...
Thought this would be something others with 3510 or 4110 would want to check on their machines before they have a similar problem.
- JC
Hopefully it's that simple ;)
- JC
Guess what? My tach now works!
I was going to check the ground as mentioned by others, but since I found this short and fixed it, my tach has started to work again. It hasn't worked for about 2 yrs....
I will still check the ground, since that is a known problem.
- JC
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59912)
2012 FORD E-350...
1999 GENERAC 99A GENERATOR (A64280)
1999 GENERAC 99A...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
