3-Point Hitch warning NX series tractor owners
   / warning NX series tractor owners #11
There's a service bulletin about wiring under the hood something about them rubbing some were back the motor toward the dash they added some wire protection with clips to mine free warranty work check with your dealer when you have it in effects some nx models not sure which ones
Be nice if somebody could post the bulletin. Next time I get out to my tractor, I'll pop the hood and look at the wiring harness routing.
Cab wise, the loader hoses rub on the forward right lower edge of the cab.
   / warning NX series tractor owners #12
I don't know about the NX, but not long after I got it, my 2006 DK45 dropped a 3-PH lift arm off after losing a bale pin (ran a mower up onto a rear wheel and bent a bunch of stuff). All this stuff has bolts now, instead of pins...after all, how often do you need to remove a lift arm?
   / warning NX series tractor owners #13
So which NX do you have , cab , or no cab, hydro or shuttle ?
Nx 4510 cab hydro what I got from the dealer was nx series he did not specifically say what nx but mine was one I also said something about the hydraulic lines right front of the cab mine are all zip tied and long enough they do not rub one just barely touches he said they were going to let Kioti know one of the new ones they have on the lot were severely touching
   / warning NX series tractor owners #15
Ok thanks was just curios , I had checked my loader hoses after I bought mine and didn't have any hoses rubbing on mine either.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
1991 Cummins NT-855-G5 250kW 3-Phase Diesel Generator (A55851)
1991 Cummins...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
